04-06 GTO Bogart D10 drag wheels
You definately need ARP wheel studs for longer thread length. With the spacers will clear. I did grind my calipers a little bit on the front to not run a spacer at all in the front. Rear I had to bend the brake lines a tiny bit for a little more room but nothing major.
