Harrop 12-Bolt IRS Bolt in Center sections
I've had some people asking about the Harrop 12 Bolt IRS complete center sections.
Here is what I can do on them.
Complete 12 Bolt with a Harrop Truetrac diff and gears of your choice for $3750. shipped to your door. They are normally around $4,000. plus shipping from Australia.
http://shop.gforce1320.com/product.s...3&categoryId=7
The Harrop 12 Bolt comes complete with big billet 31 or 33 spline stubs.
It will also bolt right up to the GTO half shafts so if you have our half shafts or anyone elses they will still bolt right up.
It even comes with a special Harrop sports cover in a 12 bolt version.
The GTO driveshaft will not work, it is 20mm (.78") too long so you'll need a shorter driveshaft.
I can supply one of our custom 3.5" aluminum driveshafts and billet pinion yoke for $799.
Or our big 3.75" Carbon Fiber driveshaft and billet pinion yoke for $1199.
If you want to add a set of our Level 2 half shafts at the same time then I would knock $100. off the price of those, $799. (regular $899.)
Here is the Harrop 12-Bolt on our web site. More information is available there.
Yea but not sure what you would use unless you fabbed one it your self. The GTO cover will not fit.
Thanks
Chris
