GTO headers and exhaust
F1 performance has a GTO exhaust ready to ship. The exhaust comes in mild steel w/high temp paint or Stainless with polished mufflers. 2.5" True dual exhaust specificly built for the GTO.
We also offer These excellant quality Pacemaker 1 5/8" try-Y Headers in Mild steel high temp painted or with ceramic coating or Stainless steel.
All parts were built on a GTO so no fittment or quality issues.
F1 Performance 2.5" True Dual exhaust mild steel $475.99
F1 Performance 2.5" true Dual exhaust Stainless $975.99
F1 performance 3" also available call for details.
Pacemaker 1 5/8" Try-Y header in mild steel $479.99
Pacemaker 1 5/8" Try-Y header ceramic coated$699.99
Have a great day Nate
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
They do look like the RHD version but then who is to say that they need a differrent version for the left hand drive cars. The space on the steer box side might be different, Have used these on a stock motor work really well low to mid range.
They are built for the GTO not the right hand cars. They are a Try-Y design and are split for ease of instalation. Don`t know exact hp #`s but headers on an LS1 have been good for 20-30hp over the stock manifolds.
Nate
Nate
I just looked at the installed picture and that makes more sense. The first picture looked like only 1 side (our passanger side) got a tri y setup. but in the installed picture both sides had the tri y. you will definatly need to do something to get by the drive side steering assembly. do you need to drop the rack to install them and can this be done without a lift?
Hi Guys,
I have a LHD "Lumina" (sedan version) and have had these headers (HPC coated 1-5/8" version) fitted to my car for over 18 months.
The rack has to come off to fit them, and a couple of heatshields need fitting to the rack, between the headers and the rack boots to stop the rubber being burned.
They clear the steering with no problems.
They are not the same as RHD version.
The bulkhead-to-chassis rail stiffener plate bolt HEADS where they screw on the chassis rail, on the LHS of the car (steering side) need to be trimmed off to stop rubbing against the headers when the engine moves under torque reaction.
They along with a 2.5" twin system wake the car up enormously.
With a PCM re-tune I gained 55rwhp. With power increase throughout the whole rpm range.
--- Sid447 ---
--- Sid447 ---
The steering coupler needs to come out but the rack can stay. They take only about 3 hours to install. I will get some dyno`s of the intake, headers and exhaust soon.
The one pictured uses the stock cats you could add any cat you wanted. It is real simple to add between the cat back and headers.
Nate
Nate
https://ls1tech.com/forums/attachmen...achmentid=2916
Those are not the stock cats...
Not sure if those were the ones you said use the stock cats.
No the one in the pcture is not stock but you can easily add the stock cats in.
"The rack has to come off to fit them, and a couple of heatshields need fitting to the rack, between the headers and the rack boots to stop the rubber being burned."
The rack does not need to be removed and the headers include the needed heat shields. There is also no need to grind any bolts on the GTO.
Nate
Nate
Originally Posted by Nasty N8
New pics of the headers
Nate
Nate
I'd really be interested in some dyno numbers as well. Specifically I would like to see a comparison from stock everything, cat-back vs stock exhaust on headers and manifolds, and headers vs stock manifolds on stock exhaust. I'm very interested if the numbers are there. Thanks.
Dave
Dave
I have not got any dynoes here as of yet I have the company in Australia has done the testing of these. They have seen between 17-25rwhp fot the headers alone.
Yes We can get them to you in the middle east.
Nate
Nate
