Pontiac GTO 2004-2006 The Modern Goat
drag bags in
Old 05-06-2012 | 10:30 PM
BSGTOLS2's Avatar
Default drag bags in
put in my drag bags on saturday...i put the bmr ones in...it was a breeze...no prblems at all and corrected all my problems....just had to brag...now the suspension and tires are set up for some power time to order my cam
Old 05-07-2012 | 10:37 AM
joeyagls1's Avatar
Nice, what Cam you getting BSGTO? I need to get me some drag bags.
Old 05-07-2012 | 12:30 PM
youngbuck's Avatar
What do the drag bags do?
Old 05-07-2012 | 09:34 PM
joeyagls1's Avatar
Im pretty sure they just stop it from squating with you give it gas. the BMR drag bags.
Old 05-08-2012 | 02:43 AM
BPP's Avatar
BPP
Yeah they raise the rear end and help with squatting
Old 05-08-2012 | 04:44 PM
Ian06GTO's Avatar
How hard were they to install??
Old 05-08-2012 | 05:37 PM
gconnoyer's Avatar
stupid easy.
Old 05-08-2012 | 06:11 PM
BSGTOLS2's Avatar
they are very easy to install just popped my springs out and squished them in and ran the lined to my trunk. lifted my rear about an inch giving me plenty of room for my drag radials.....as far as the cam i am trying to deicide on what i want....prolly texas speed 224r
Old 05-08-2012 | 08:12 PM
ULTIMATEORANGESS's Avatar
Smile
i would also think theyll help reduce wheelhop dramatically.
Old 05-08-2012 | 09:43 PM
joeyagls1's Avatar
Yeah, if the installation is easy I will buy me a BMR Kit of them. Good deal!
Old 05-09-2012 | 09:45 PM
BSGTOLS2's Avatar
Started at about 8am done by lunch
Old 05-09-2012 | 09:52 PM
mild83's Avatar
How is the ride with them installed?
Old 05-09-2012 | 10:25 PM
BSGTOLS2's Avatar
a little stiffer but not bad at all...i like it more honestly....and when you smash the peddal you really notice the diffrence...
Old 05-10-2012 | 12:46 PM
silver02Z's Avatar
I went with the Mazda MVP bags and love them. They are smaller which is what I wanted because I have Pedders lowering springs. Spring removed from the car, much easier than leaving it in.. Raises the rear, eliminates wheels hope, I'm happy!
Old 05-10-2012 | 03:21 PM
Sick LS2's Avatar
i have the mpv ones....what pressure does everyone run? i run 15psi...took it to the track in street trim with 15psi and wheel hopped like a bitch....next track day ill bump it to 20psi.
the pic in my sig was the run it shook the dam car to almost pieces
Old 05-10-2012 | 04:35 PM
silver04goat's Avatar
Definitely need to look into these. Sounds like a good mod and not too expensive
Old 05-10-2012 | 09:32 PM
BSGTOLS2's Avatar
i am running 15 psi daily
