Leaking Dot 4 Fluid Beneath center of Bell Housing
What are the chances all I need to do is pull tranny and tighten nuts holding both Clutch slave lines? As opposed to having to replace the entire slave cyl?
Just watched a you tube video of some chic replacing the slave cyl and adding a new remote bleeder:
Yenn Time Ep 1 - 2006 GTO T56 Tremec Transmission Drop Clutch Slave Replacement Remote Bleeder - YouTube
Has to replace my slave cyclinder a few months ago. New ones not that bad price wise. Didn't see a whole lot of fluid but I knew it was gone when I got in my car and the pedal went to the floor with ease. Might be worth replacing the clutch or disk while your in there . I replaced my act 4 puck unsprung disk at the same time. Don't understand why they put the cyclinder there.
