Nasty Front End Shake 75+ MPH
OK, so I have been trying to fix my front end shake since last fall. I have a 2004 GTO A4 and this is what I have tried so far:
1) Rotate rims from front to back
2) New tires
3) Pedders 'fix' - Radius rod bush., sway bar bush. & endlinks, X-member bush.
4) Checked the wheel bearings - better than new according to the measurements
5) Checked the rotors for 'flatness' - OK
6) Cleaned the hub/rotor/rim faces and re-torqued everything to spec. (many times)
Anyone got any other ideas?
2) New tires
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Struts don't have anything to do with that.
Have you checked hub run-out? That is probably the only thing that would cause it since you eliminated everything else. I don't remember off top of my head, but if it's more than certain value, you need new hubs.
My guess is the rims are bent. If you still have the stock 17" wheels, get rid of them! I had the same problem with my stock 17's and replaced with ROH Drift-R's and shake went away! There is no guarantee that this is the problem but I would check it anyway.
Are the wheels loaded with weights? If so bent rim.
Did you just rotate them or have them balanced as well? Just because they are bent doesn't mean that they will take alot of weight. I have balanced some pretty nasty wheels and only had to put on 1.5 ounces.
