lt1 RR oil pan or stay stock?
i'm going to be putting in a fresh motor with an m6 swap in the next couple of months. i'm wondering if before i go through with the swap if it would be needed to go ahead and spend the coin on a road race oil pan. i plan on using long tube headers, so if that is an issue it will play a factor. the motor will be all stock internals, stock heads, just full bolt-ons. won't do a whole lot of road racing and auto-x, but hopefully 1 event every couple of months, maybe more down the road. opinions/facts please
You can get a stock style pan with internal baffles and overall better oil control.
If you can afford it and your headers will clear, a good canton kickout RR pan would be your best option.
improved racing makes an oil baffle for LS1s. not sure if they do for LT1s. if youre only going a few times a year, its not vital. you dont need anything extra for autox, and can just overfill by a quart if you do a track day.
Just my .02
Sebring results
Road Atlanta results
So what tech do you have that shows sustained high G turns will kill a set of bearings? We are talking about LT1's and not LS1's by the way so don't go there for your back up. It's well documented that LS1's have oil starvation issues.
No I'm not kidding and I'm not some casual once a month autocrosser. I've logged thousands of track miles at speed on mine. I'm out there competing in NASA Time Trials so when I say racing I'm not talking about HPDE's. I'm not the fastest but I do run respectable times, so not the slowest either. I run in TTB so to back up my claims here are results from June at Sebring and August at Road Atlanta.
Sebring results
Sebring results
Listen to this guy.
My experience is much the same.
I spent the bucks on a Canton 242T for my 96 CMC Firebird and have built a couple LT1 cars for customers that I didn't bother with an aftermarket pan.
I wished I had saved my money.
