First PE of the year
Got some decent gopro videos and got a view you don't see often on a Fbody.
Engine seems to be cutting out after going around some of the turns then going WOT. You can hear the interruption in the exhaust note and I felt it in the car. Not 100% why that is. Car does not have Traction Control. Dun Dun Dun
MVSCC PE1 2015 - YouTube
I used red lock tight on mine and check it every 2-3 races but I also drive to my events on shitty MA roads. I've had a propeller bolt fall out once on the highway.
Good point. I think I have a rod end that is worn out. There is some play in one that I need to take the propeller and move it down to get the rod end. It keeps "popping" like it gets bound up due to the play.
I'll be sure to toss some red Loctite in there upon reassembly.
Awesome view, Ive been wanting to see something like that since the watts link became available for our cars. Ive been wanting to buy a gopro just for that.
What is the engine/exhaust setup on the car? Its sounds mean as hell.
I'm not completely sold on the exhaust note. Still is not as smooth as I would like it to be in lower rpms in 2nd gear. It will do for now though. Higher rpms it sounds pretty good and mean.
