Lightweight clutch
Ive been looking at the spec stage 3 and 3+'s, i think with a lightweight flywheel its still going to shave 20lbs off the factory setup but come in under 1000$. my requirements are a little...different...than the full road race guys. my car is not a street car but i cant have an on-off switch for a clutch because it will destroy transmissions and rear ends when i clutch kick at 5000rpm and 90mph haha. clutch has to absorb some of that shock (hence why im looking at sprung disc's)
i have(had) an RPS on my last engine and LOVED IT. never had any issues.
Install the flywheel and torque to 107 lb/ft in a star pattern:
Clutch cover, flipped upside down:
Pressure plate added making sure everything is ultra clean:
Then the disk:
This is what a real clutch alignment tool looks like:
Alignment tool inserted. Disk lined up. Clutch cover tightened to 24 lb/ft with a dab or red locktite:
All done. The whole assembly with the flywheel and clutch is about 22 pounds:
After installing the clutch I double checked my setup height to make sure that the throw out bearing was in the proper position. Everything looked great. Transmission was attached to the engine and the engine is in the car. I will take more pics later.
Andrew
Andrew
I spoke with someone at QM about a year ago, and they couldn't hook me up with an LS1 clutch setup. They thought they might have some parts, but they weren't in production, and couldn't find the flywheel. All they could remember was they put what I was looking for in a car that someone did for Goldberg. Eventually I gave up. The 8.5" you're showing is exactly what I was looking for.
Andrew
What do you consider streetable?
Anderw
It all comes down to how much maintenance you are willing to do. For me taking the trans out, inspecting the clutch, replacing the disk, etc...., is not a huge deal. For others its a major hassle that they do not want to bother with.
Is it streetable? In my opinion yes, but only as long as you do not expect a very long life from the clutch.
Andrew
Andrew
Andrew
The stock TOB cannot be used. Solution is pictured below. You can contact Quarter Master directly and get info on part numbers. Any of their dealers can take the order for you.
Andrew
