What trans cooler are my boosted fellas running with your 80e setup?????
Old 08-01-2016, 01:14 AM
gols1go's Avatar
Default What trans cooler are my boosted fellas running with your 80e setup?????
I have a 80E in a 99 f body. Just trying to see what trans cooler are you guys using to keep the temps in check. This will be ran without going through the radiator as this car will never see the winter. Any help is appreciated and pics even more! Thanks in advance!
Old 08-01-2016, 09:17 AM
laytoncamaroz28's Avatar
I wanted to keep less heat up front so I decided to try mounting mine to the bottom of the trunk. I got a loose 3600 converter and cruising it never exceeds 170F. I hot lapped at the track and it reached 200F after about 5 passes. It's a power stroke trans cooler and no fan on it.
Old 08-01-2016, 09:23 AM
denmah's Avatar
i hear those powerstroke ones are ******* beast!
Old 08-01-2016, 09:49 AM
Restricted User
JoeNova's Avatar
I use the ebay $130 dual pass ones. Work great.
Old 08-01-2016, 10:10 AM
35spline's Avatar
I have a Hayden 679 in front of the radiator on my N/A Nova with a tight 80e converter. Cruising around this summer in the Texas heat trans temps are 155- 160F at the same time my engine temp runs 200F.
Old 08-01-2016, 11:13 AM
gsteele's Avatar
Where is everyone putting the temp sensor? Big difference between transmission pan and inline going from transmission to cooler.
Old 08-01-2016, 11:32 AM
Restricted User
JoeNova's Avatar
Stock 80e temp reading logged in HPTuners.
Old 08-01-2016, 12:21 PM
Very pleased with this one! But it's only one ib ever used. And I'm also using factory sensor via efilive
Old 08-01-2016, 09:34 PM
CameronVic's Avatar
I got one from the junkyard, and had some male -6 ends welded on. Bar and plate, from a ford econoline van. $17.
And it didn't get over 180 on this day stuck in traffic. Having it priority mounted (not underneath the car where the air is heat soaked) allows for a smaller cooler.
Old 08-02-2016, 06:11 AM
forcd ind's Avatar
I have used the B & M ones with 6 AN fittings, like 12" x 12" or so, I mounted it level with the bottom of the front bumper at a slight angle, temps were usually in the 150-175 area, depending on outside temps and if locked up or not
Old 08-02-2016, 08:43 AM
lmt0705's Avatar
I'm running a b/m one with a fan mounted up inside the rear bumper with -6 lines and an air damn to help with flow, pretty good with street driving but the transbrake gets the fluid crazy hot to the point of spitting out of the breather, switched over to LAT transmission oil and temps much lower and no more spitting
Old 08-02-2016, 11:45 AM
Forcefed86's Avatar
I used Derale dual core trans cooler on my RX-7. 10x14.5. Mounted in the rear. On the Trans brake for about 3-5 seconds and at the end of the pass it's sitting at 210-220* I always thought that was kinda high and figured that trans cooler would do a better job. That's an oldschool Grandnational intercooler fan as well, known for putting out a ton of CFM.
The large china oil coolers seem to work really well. Buddy uses one on his TH400 and hot laps the crap out of the thing. Says he has never seen over 200*. Drops down in the 130’s cruising. I picked up this one to try on my next build. Hope it works that well! I grabbed some AN10 to AN6 adapters for $12.
13"x9"x2" 30 Row.
http://www.ebay.com/itm/Universal-Al...FWd2NF&vxp=mtr
Old 08-02-2016, 09:23 PM
Photochop's Avatar
Interesting, where does he have the cooler mounted? Fan on it?
Old 08-02-2016, 10:01 PM
Forcefed86's Avatar
Has it up front with a fan.
Old 08-03-2016, 05:18 PM
LS2 67GTO's Avatar
13"x9"x2" 30 Row.
I run that china cooler on my TH400 Foxbody. I installed a fan controlled by my MS3X, it never kicks on keeps trans nice and cool. Have not had a chance to get to the track and test it with T-Brake. Have done a little testing in driveway and never got over 200*. I think I will use another one on my C10.
Quick Reply: What trans cooler are my boosted fellas running with your 80e setup?????
