4L80E cooler line fittings
I was concerned about the holes on the bolt part but as you can see they are very large.
![](https://cimg9.ibsrv.net/gimg/ls1tech.com-vbulletin/1600x1600/s_l1600_556b0dd8cbc2da81a5b80a12baca577d343459b7.jpg)
Yes, the clearance is excellent. I was concerned if the fittings would flow properly given the sharp turn of the fluid path. I hope they work fantastic, I may have to switch to them.....
S.F.
S.F.
I have closed this thread because the OP started a sequel:
https://ls1tech.com/forums/automatic...-fittings.html
If you have anything to add, you can post it there.
Thanks.
Thanks.
