4L80E cooler line fittings
Old 09-25-2016, 07:47 AM
wht/73's Avatar
Default 4L80E cooler line fittings
Anyone use these?
Looks good as it will be pretty tight in the tunnel.
wht/73 is offline
Old 09-25-2016, 03:41 PM
Area 51 Racing's Avatar
I've haven't used them particular fittings but my 4l80e fittings came from Sweet Performance and work like champ. Wish I would of saw these, I'd rock em with no concerns. Buy them.
RyanR
Area 51 Racing is offline
Old 09-25-2016, 04:25 PM
StolenFox's Avatar
Originally Posted by Area 51 Racing
Buy them.
RyanR
Agreed. Then please report back how they work out. I almost bought them as well but went with the standard ones from Sweet Performance. Now thinking I should have bought them due to trans tunnel clearance on my swap.
S.F.
StolenFox is offline
Old 09-25-2016, 04:29 PM
wht/73's Avatar
S.F.
Yeah the ones shown are for my 2000 trans and needs the one with the long tube for the rear cooling.
I was concerned about the holes on the bolt part but as you can see they are very large.
wht/73 is offline
Old 09-25-2016, 04:32 PM
wht/73's Avatar
Here they are installed!
TONS of clearance.
wht/73 is offline
Old 09-25-2016, 04:50 PM
StolenFox's Avatar
Yes, the clearance is excellent. I was concerned if the fittings would flow properly given the sharp turn of the fluid path. I hope they work fantastic, I may have to switch to them.....
S.F.
Old 09-27-2016, 10:30 PM
Firebirdmuscle's Avatar
I used regular an fittings on mine, but did have a buddy that used the banjo's and like you his clearance was great
Firebirdmuscle is offline
Old 09-28-2016, 12:40 PM
Cpt.Derrek's Avatar
I use them fitment was great! I ended up only using 1 of them as I was able to use the stock feed line.
Cpt.Derrek is offline
Old 10-11-2016, 01:37 PM
mrvedit's Avatar
I have closed this thread because the OP started a sequel:
https://ls1tech.com/forums/automatic...-fittings.html
If you have anything to add, you can post it there.
Thanks.
mrvedit is offline
Quick Reply: 4L80E cooler line fittings
