Diameter Transitioning, Hotside
I wouldn't go to 2, maybe 2 1/4, but then again, I wouldn't do 3. I think either way, it all works, but I would think it will spool quicker with 2 1/4 -2 1/2. It's about velocity, just like a carb, bigger isn't always better, but that doesn't mean it wont work.
Depending on how long it's been together, and if you have any data logs, I would love to see some data once you change it.
Not sure I understand what you're wanting to do. What size of pipe do you have off the manifolds? I went 2" off manifolds to 14" of 3" and I start to see positive pressure at 1800 rpm.
Sounds like he is redoing the 3" pipe that connects to the pipe in the pic. The pipe in the pic is the crossover where two 2.5" pipes merge into a single 3" pipe. From there, the 3" pipe on the crossover connects to a 3" up pipe with the T4 flange.
Since he is redoing the up pipe, I think he just wants to know if there is a better size to reduce down to before the T4 flange.
IMO, if it spools fast enough as is, then leave it. If it take a little time to spool up, reduc it down to 2.5". I would leave it at 3" personally, but I'd be interested in the results.
Jon
Jon
