12 Second Club In the 12s yet? Come inside!
Stock stall 2.73 car first 12
Old 11-01-2016, 01:21 PM
Freshsqueezd's Avatar
Default Stock stall 2.73 car first 12
car is a 01 z28 with headers true duals slp lid and ported tb on Mt drag radials (they made the car slower)
Old 11-01-2016, 03:34 PM
ironmikektm525's Avatar
Good run! What was da?
Old 11-01-2016, 07:21 PM
spicebird98's Avatar
U don't need those mickeys with the power level and gearing you have, they way a ton. We went 12.4 at 113 with basic bolt ons stock stall. Keep working at it
Old 11-01-2016, 10:29 PM
fastsspr's Avatar
What altitude above sea level is the track? The car is tunned?
Old 11-02-2016, 08:06 AM
Track is 74ft above sea level it was really good air not sure on da but the car has a frost tune and believe me I kno I don't need the drs they slowed the car up a good bit I got a 3.42 rear for $200 I'm gonna swap that in and see if that makes up for the tires until I can finish saving for my stall
Old 11-02-2016, 08:09 AM
I'd love to see a 12.4 what was the setup if you don't mind me asking?
Old 11-02-2016, 09:52 PM
Sure, it was a Lid, Super sucker ram air duct, bbk 1 3/4 mid length headers, catted bbk y pipe, hooker catback, toyo TQ drag radials on stock wheels. Bone stock suspension but removed front sway bar. Best with 2.73's was a 12.49 with a 1.90 60', switched to 3.42's and went 12.42 with a 1.87 60' if I remember right. Full weight t top/leather car with the spare tire removed.
Old 11-03-2016, 08:23 AM
I wish i could see a 60" in the low 1.9s or high 1.8s the mickeys are killing me for sure car bogs like crap that 12.96 pass the car was actually spinning tho I aired em up to 35 to try to help with the bog and drove around the water box and just did a dry hop best 60 with the car was a 1.99 but that was the cars worst pass too dead hooked but took a while to get the rpms back up
Old 11-03-2016, 03:48 PM
Strong run for not even full boltons! Must of had some good da.
Old 11-03-2016, 07:35 PM
murphinator's Avatar
are you mashing it off idle to get the most "flash" out of the convertor ? or are you preloading it/brakestanding ?
Old 11-03-2016, 09:06 PM
I was leaving off idle/flashing its slower off brake stalling it went a 13.05 brake stalling with a 2.00 60ft
Old 11-28-2016, 05:12 AM
Default New pb guys
I just matched spicebirds 12.42 last night with just a 3.42 gear change other than that everything is the exact same
I was in the left lane it was a freakin Chrysler crossfire in the right lane I barely held him off
Old 11-28-2016, 05:13 AM
I leave off idle that's how I get my best ets
Old 11-28-2016, 07:49 AM
rybern's Avatar
Very impressive times with those mods.... especially with stock converter. I couldn't get below 13.0 with the stock converter(n/a and stock cam).
Old 11-28-2016, 08:29 PM
nice job , picking up a good 4k stall should have you around 11.9/12.0 in similar racing weather
Old 11-28-2016, 08:37 PM
sillysspeed's Avatar
Nice times! Stock converters leave a lot to be desired for sure. My best 60ft was 1.88 with it. Felt like it took forever to crack 1.99 and faster 60ft.
Old 11-28-2016, 10:04 PM
jhshnh's Avatar
Very nice. I went 12.89 with stock stall and 2.73s. I went with et streets and 4k stall and went 12.29 with stock gears still.
Quick Reply: Stock stall 2.73 car first 12
