holley touch screen mounting in f body
Old 12-21-2016, 12:40 PM
lmt0705's Avatar
Default holley touch screen mounting in f body
i know this may be the wrong forum but a lot of us run these here. Im looking for pictures and ideas on how to mount the holley 7in touch screen into my 4th gen transam dash.
thanks!
Old 12-21-2016, 01:45 PM
323z's Avatar
Ducktape it to the steering wheel, it's just a 4th gen.
Sorry I am no help, this is where I will put my 7' holley screen in a Z, a 350z.
Which doesn't help you at all. Name:  DSC05108_zpsrhxb9d18.jpg
Old 12-22-2016, 08:16 AM
lmt0705's Avatar
Nope, looks cool though
Old 12-22-2016, 09:27 AM
RedRocketZ28's Avatar
If you're on Facebook look up Los Vasquez. I know he made templates for the smaller screen but not sure about the bigger one.
Old 12-22-2016, 09:52 AM
oscs's Avatar
I talked to him last night after seeing this post. He doesn't make them anymore.
Old 12-22-2016, 11:08 AM
I tried! LOL.
Old 12-22-2016, 11:20 AM
oscs's Avatar
I tried! LOL.
We where thinking the same thing
Old 12-22-2016, 12:52 PM
SoFla01SSLookinstok's Avatar
Not a Holley. Just for maybe an idea.
Old 12-22-2016, 10:17 PM
MUSTANGBRKR02's Avatar
Mine will be going where the radio was
Old 12-23-2016, 08:09 AM
lmt0705's Avatar
I'm going to play around with some abs plastic and see if I can mount it where the stock gages were
Old 12-23-2016, 08:26 AM
Keep the thread updated so the next guy can find it. Mine will be going in as soon as it comes in after the first of the year.
Old 12-23-2016, 07:01 PM
Fat Jesus 808's Avatar
Old 12-23-2016, 07:05 PM
So kinda like that?
Old 12-23-2016, 10:19 PM
ta02zx10r's Avatar
What size of screen is that one
Old 12-24-2016, 12:06 AM
The 7" touch screen
Old 12-24-2016, 06:29 AM
NitrOmm's Avatar
After removing the cluster, there is plenty of room to mount. I plan on taking the plastic/glass part of the original cluster & cut out the center to the exact size of the screen & use that as the filler for either side of the screen. It already has the perfect concave & fitment.
I will have it dipped or just painted from the inside. Should clean up nicely.
Old 12-24-2016, 02:08 PM
Looks good
Old 12-25-2016, 10:17 PM
lmt0705's Avatar
How is the screen mounted? I've almost got mine done, I took a piece of abs and screwed it to the bottom tabs on the from bezel then took a torch to the plastic on the sides and was able to make the plastic bend and close the gaps on the sides. I haven't cut the hole for the screen yet, I was thinking I'd make a mount off the fiberglass framework and slide the bezel over it
Old 12-26-2016, 11:57 PM
I used abs plastic and it bolts to the stock cluster bolt holes. And the dash is bolted through the abs plastic from the back. I just cut a little hole for the USB and can cords to go through
Old 06-08-2017, 03:03 PM
WS6HUMMER's Avatar
You have any pics? I'm about to try to mount mine.
Quick Reply: holley touch screen mounting in f body
