2000 z28 4.8l turbo build
Old 02-17-2017, 10:11 PM
ep142's Avatar
Default 2000 z28 4.8l turbo build
After years of cam bolt ons and spray I decided to switch, I decided to build my own setup, I purchased a front clip and got to work. I'm keeping it simple keeping A/C, stock fans and accessory location.
Old 02-18-2017, 05:37 AM
ScottyBG's Avatar
Will your steering shaft clear with the turbo there?
Planning to use a scavenge pump too?
Old 02-18-2017, 06:39 AM
1BADTRANS's Avatar
Very different !!
Old 02-18-2017, 10:06 AM
ep142's Avatar
the steering shaft clears great and no pump needed, I have a lot more pics.
Old 02-18-2017, 10:39 AM
ep142's Avatar
The front clip I used
Mock up motor bolted to the subframe and installed in clip
Used a spared piece of exhaust pipe to support the turbo so I could find the best spot for it. You can see how the charge pipe is going to be incorporated into the subframe
Its snug but enough room for the steering shaft, also started a motor mount bolt to check clearance
Old 02-18-2017, 12:07 PM
ScottyBG's Avatar
That is pretty neat. I've never seen a turbo there before on a 4th gen, or any car for that matter. Are you going to run a pipe into the turbo inlet so it doesn't have to suck hot air from that header you made? Very original design, what gave you the idea to do that?
Old 02-18-2017, 12:30 PM
ep142's Avatar
yes going to run a filter under the fans then back to the turbo inlet. I wanted to do something different and not mess with the accessories or fans
Old 02-18-2017, 03:02 PM
ep142's Avatar
I had hours in moving the turbo 1/8 inch at a time to get it just right
Pic of the driver header starting its journey down to the crossover pipe
Installed a v-band for easy disassemble
Best place I could find for the gate, not alot of room in 4th gens...you can see the charge pipe that is inserted into the k-member it will get finish welded and structural part of the k-member
Old 02-18-2017, 10:18 PM
SSZ
SSZ's Avatar
Holy does that look tight!!!!
Old 02-18-2017, 10:19 PM
SSZ
SSZ's Avatar
What turbo is that?
Old 02-19-2017, 07:39 AM
ep142's Avatar
Originally Posted by SSZ
What turbo is that?
on3 76mm
Old 02-20-2017, 10:35 AM
mOtOrHeAd MiKe's Avatar
Location: Ottawa Ontario, Canada - where arguing "DA" is for the slow and weak...
Well done!
Old 02-22-2017, 10:10 AM
merim123's Avatar
very well done. I bet if you went with a smaller turbo, you could do twins and not have to cut into the kmember. At least my going in theory, but love the approach!
Old 02-22-2017, 11:28 AM
fastrabbit's Avatar
id like to see twins mounted that way. keep up the good work
Old 02-22-2017, 11:35 AM
svslow's Avatar
Very cool.
Old 02-23-2017, 10:11 AM
ep142's Avatar
Pic of the driver side motor mount
Driver side mount looks snug but should work
Old 02-26-2017, 07:39 PM
ep142's Avatar
Finally welded and painted, all the parts just about done for the kit you can see how the charge pipe is indergrated into the k member
Still have to wrap the header and cross over
Old 03-07-2017, 08:10 PM
ep142's Avatar
Time to put the kit in the real car
Pulling oil pan to weld fitting for oil return
Old 03-07-2017, 08:29 PM
coltboostin's Avatar
Very Nifty!
Old 03-08-2017, 08:17 PM
ep142's Avatar
Got the header and crossover wrapped
Put a walbro in years ago but pulled the tank to install a second...look at the nasty 10 bolt still kicking ***
Quick Reply: 2000 z28 4.8l turbo build
