210* trans temp with cooler
Old 03-11-2017, 08:57 AM
z28_YOU_HO's Avatar
Exclamation 210* trans temp with cooler
Drove 5 miles to work. Stop and go traffic and my temp gauge is reading a hair under 210 (I do have it in the test port so I know its 10-15* higher).
Have a circle d 3600 stall and a cooler from jegs.. This cooler to be exact .
http://www.jegs.com/webapp/wcs/store...rsistYmm=false
Any ideas?
Old 03-11-2017, 09:04 AM
98CayenneT/A's Avatar
IMO that cooler is absolutely worthless.
Did you bypass the stock cooler in the radiator?
Where is that cooler mounted?
I would go with something like the b&m 70266 stacker style cooler and you absolutely will see your temps drop.
That cooler you have is WAY to small and a VERY poor design imo
Old 03-11-2017, 10:31 AM
z28_YOU_HO's Avatar
I have it mounted "dope" style. I did not bypass the stock cooler lines.
Game ova's Avatar
Any ideas?
Get this and be done with it. I use one with a 400 and 9.5 inch converter in a heavy car with tall gears.....still cool.
It's a derale cooler and it WORKS.
Old 03-11-2017, 10:40 AM
ragtopz28's Avatar
^^^This exactly^^^
We live in FL man, why let the hot rad preheat the tranny fluid. I run the B&M, radiator bypassed, and mounted it in front of the driver side fan. Runs 150-170*
Old 03-11-2017, 10:42 AM
Ya, that is just not going to cool anything mounted like that with that style/size cooler.
Get a plate/stacker style cooler and mount in front of radiator or mount dope style but go with what Game Ova posted.
In either situation bypass the radiator cooler.
Old 03-11-2017, 11:39 AM
LS1Tech Sponsor
performabuilt's Avatar
210 is not to high particularly running through the radiator which actually preheats to around 195 degrees , In your location as mentioned a large stand alone cooler with a fan would be a much better overall choice,
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-11-2017, 01:44 PM
z28_YOU_HO's Avatar
Would it be a benefit to bypass my cooler lines? with my current trans cooler? I'm in FL so it doesnt get really cold around here...
Old 03-11-2017, 01:53 PM
Game ova's Avatar
Skip the radiator. It's completely unnecessary, with an unlocked converter you won't have any issues making enough heat to get the fluid warm.
Old 03-11-2017, 02:02 PM
I would throw that cooler in the garbage.
Here is my setup.
Old 03-11-2017, 02:24 PM
z28_YOU_HO's Avatar
Actually I have THIS trans cooler
http://www.jegs.com/i/B-M/130/70264/10002/-1
Old 03-11-2017, 02:27 PM
z28_YOU_HO's Avatar
dbl post -_-
Old 03-11-2017, 02:39 PM
Game ova's Avatar
I used to rock that one back in the day, it's aight I guess. But like I said earlier, that Derale is BOSS.
Old 03-11-2017, 03:45 PM
z28_YOU_HO's Avatar
Hmm, might try the bypass and see what happens. Can always upgrade if it doesnt cool it down
Old 03-11-2017, 08:58 PM
NHRAFORMULA00's Avatar
Bypass the radiator completely. Get the largest cooler that you can find and put it in front of the radiator.
Quick Reply: 210* trans temp with cooler
