LS2 F1A new build. Let the fun begin.
Old 11-19-2016, 11:55 AM
  #81
Game ova's Avatar
If you don't have a spray system, I'd strongly recommend over filling your trans....if it isn't already.
Old 11-20-2016, 06:53 PM
  #82
neverstop's Avatar
haha....sounds just about exactly how I felt with my car first time got it back with the new motor/setup.
I would go with 3.42 gears. I don't know what your torque curve is like but with my 427ci and D1 making 900whp and 860tq it will light up my nt05r into 4th gear on the freeway sometimes, and even with brand new mt et street R and 17" rim zero traction on street or airstrip in 1/2nd gear. So no need for lower gears. I think for >700whp 3.42 are perfect unless you have a powerglide or maybe are drag racing a lot on real slicks.
I also overfill my t56 and it's working great at my power level for quite awhile now and shift/feels/sounds like new.
Old 11-23-2016, 01:53 PM
  #83
NitrOmm's Avatar
Thanks guys. Appreciate the tip.
Overfilling it is.
Old 03-12-2017, 09:02 AM
  #84
NitrOmm's Avatar
UPDATE:
I'm REMOVING THE WASTEGATE:
It was a good experiment. The results along with some new knowledge of what is actually happening when the gate opens, lead me to the decision.
I recently hit 500 miles ( clutch is broken in). With that said, the fun began !
All that I can say is that "on paper " the concept of an "earlier TQ curve" , sounded good. The reality is, I'm completely over powered for the street. I'm sure there are plenty of " I told you so" comments ...... but I had to try for myself. To cut to the chase, now that I am free to push the limits , the power band is too explosive & the car becomes a Huvver Craft at any speed with only a 1/2 throttle pop.
In addition, this decision to experiment with the gated system was made a few years ago. Since then I did quite a bit of research and was lucky enough to have one of the ProCharger engineers help get into my thiick head the understanding of compressor maps & the pressure being put upon the ProCharger & crank once the gate springs open & creates an artificial leak. Bottom line, for my needs this was not a smart option. If anybody is interested, there is a link at the bottom. It is a thread from another site re: the waste gated systems & comments from a ProCharger rep.. This is what lead me to more research, a conversation with the ProCharger engineer & ultimately the decision to remove the system.
We are in the process of removing the Wastegate & boost controller. Replacing the 3.6" head unit pulley with a 4". While she's up on the racks I'm finally replacing my 4:10 gears. I'm leaning heavily toward 3:73's while considering 3:42's.
I'll continue down the rabbit hole w/More fun to come !
http://www.corvetteforum.com/forums/...rocharger.html
Old 03-14-2017, 10:28 AM
  #85
UNDER PRESSURE MOD
The Alchemist's Avatar
I definitely recommend going with the 3.42 gears. That lower rpm power will be much more usable and it makes for longer pulls as well.
Old 03-14-2017, 10:53 PM
  #86
Monte4ever's Avatar
I have 3.70 rear gears but I'm running 345-35-18s (28") out back. Its probably been asked before but what size tire are you running?
Old 03-15-2017, 09:03 AM
  #87
NitrOmm's Avatar
Makes sense. I can say this: the 4:10's made for a small window of pull. Blink your eye and your grabbing the next gear.
Old 03-15-2017, 09:05 AM
  #88
NitrOmm's Avatar
Toyo R888 315/30/18. ( I believe 26").
Old 03-15-2017, 10:14 AM
  #89
UNDER PRESSURE MOD
I even considered going with a 3.23 gear.
Old 03-15-2017, 01:12 PM
  #90
conan's Avatar
X2 ^^^
I'm a couple hundred HP short of this guy and i wouldn't consider going any higher than 3.42's for my 6 speed street car. I will probably go with 3.25's when I pony up for a Midwest Chassis fab 9.
Old 03-15-2017, 05:19 PM
  #91
neverstop's Avatar
lot of fast cars have gone faster by going with longer gears. different platform but that black horse turbo 911 jumps to mind. way faster in 1/2 mile with taller gearing on same motor.
Old 03-19-2017, 08:05 AM
  #92
NitrOmm's Avatar
Thanks for the advice guys.
I pulled the trigger on the 3:42's and a new Truetrac carrier.
I just realized that the new gears need to be broken in before I can really put it to the test.
Holy mackerel ....... I'm in a perpetual "hurry up & wait program" !
Old 03-19-2017, 09:06 AM
  #93
Monte4ever's Avatar
Yea, I would go 3.23 or 3.42 with a 26" tire also.
Old 03-19-2017, 07:34 PM
  #94
UNDER PRESSURE MOD
A couple heat cycles and they will be fine.... then hammer on it.
Old 03-20-2017, 01:05 AM
  #95
8 Second Truck Club
Blown06's Avatar
It can be set up to be able to beat the **** out of it right away. I've broken in numerous sets of street gears with a quick full power 200 foot rolling burnout and never had an issue.
Old 03-21-2017, 11:30 AM
  #96
NitrOmm's Avatar
This is what I was hoping to hear.
Old 04-09-2017, 08:46 AM
  #97
NitrOmm's Avatar
DYNO results. Ran out of injector @ 5,500 RPM. But I'm happy with the direction that this is going.
I was contemplating not spending the money & just live with it a while .... But a wise man suggested I do it the right/safe way. I'm putting ID1000's in this week & we will let it eat. My guess is that it will hit about 800 HP once properly fueled past peak TQ. ???
Truth is I'm satisfied with the TQ curve as it sits & really can't ask for more.
Note: The " witch doctor" wastegate system was removed & my goal for low end TQ has been attained. The 3:42's are in and what a difference all these adjustments made.
Thanks to all for the good advice. I'll post up the round two after the injector swap.
Old 04-09-2017, 12:59 PM
  #98
Mike 02T/A's Avatar
Looks good so far! I can't wait to put more break in miles on my motor and tune/dyno everything. I'm about 2.5 hours away near Tampa/Orlando area. I'd like to see yours hit 800. That would give me some hope on my new setup.
Old 04-09-2017, 02:05 PM
  #99
Rudy72's Avatar
When I see these builds, it pulls me toward the Procharger D1 or F1a and knowing most car guys, having reserve without sacrificing fun...
What made you choose the F1a?
Do you spray any Alky or Meth Mix? Just saw you are Forged ;-) Many stock internal builds use for safety in tune, detonation is the killer of Parts for sure...
Great Info & Build to learn from, so much knowledge around here!!
Old 04-09-2017, 03:09 PM
  #100
NitrOmm's Avatar
Thanks.
Patience .... Your almost there. Keep us posted.
Quick Reply: LS2 F1A new build. Let the fun begin.
