LT1 Intake
LT1 Intake
Is it possible to turn the LT1 intake 180 degrees> I know you can rotate the LS intake, but how about the LT1 intake?
Don't think you could without some welding/machining. The LT1 intake seals off the lifter valley at the front and back of the block. The intake might have enough sealing surface to cover the ridges but I don't think anyone has ever tried. You'd also have to do some grinding to fit the oil pres sender.
Thanks for the help. I have an LT1 in a street rod that does not have much room between the engine and fan/radiator. It has a fabricated fitting on the throttle body that does not have a smooth airflow. Just trying to make things easier to access.
GMPP make a carb intake for the LT1. You would need a rear standard distributor...and a carb but you could get one of those FI carbs
GMPP also makes the Opti block off plate
IDK if this combo solves your space issue
