what did you do to your firebird today?
Old 06-05-2017, 04:39 PM
  #3241
frank1313's Avatar
replaced both power window motors, window switches, lock switches and pulled as much of the aftermarket stereo equipment wires out that i could do so.
Old 06-05-2017, 05:04 PM
  #3242
JohnR's Avatar
Check out Autotrix for a relay conversion to take the electrical load off the switches and give full power to the motors.
Old 06-05-2017, 05:12 PM
  #3243
frank1313's Avatar
has anyone done this? im not really all that big on cutting in to wires, but this looks very interesting.
do i need to pull the motor back out? as its a tight fit for the connector on the motor.
Old 06-05-2017, 05:41 PM
  #3244
JohnR's Avatar
Yes, I did this to my '99 Firehawk. You don't have to pull out the motors. The kit includes relays that mount under the window switches. Plus you get a red wire that you run directly to the battery. I routed my wires through a passenger side firewall grommet below the engine computer.
John
Old 06-06-2017, 11:28 AM
  #3245
michaelhawk's Avatar
I did the same as JohnR in my 2002 Firehawk. Full power and speed to both windows motors, should have been designed this way from the factory.
Old 06-06-2017, 12:32 PM
  #3246
frank1313's Avatar
i worked for a pontiac dealer in the parts department as a manager back in the mid 90's to about 2004 and we were always replacing them the motors and regulators, i would have thought motors would have changed by now.
thank for the info and will add to my winter list of things to do!
Old 06-06-2017, 10:09 PM
  #3247
TechCam97's Avatar
I got the new steering wheel put in. The 95-02 style is waaay nicer than the 93-94 style. Much better!
Old 06-08-2017, 04:31 PM
  #3248
Saturn5's Avatar
I got my Strano springs and Koni 4/4's installed.
Still need to put on the adjustable panhard bar, but the rear end isn't *too* far from center. Then add the Strano sway bars and I'm good to go.
Old 06-08-2017, 04:33 PM
  #3249
frank1313's Avatar
any pictures yet? looking to do the same on my 02.
Old 06-08-2017, 04:44 PM
  #3250
BBWS6's Avatar
Put my rear wheels on
Old 06-09-2017, 07:42 AM
  #3251
Saturn5's Avatar
Not yet, but I did measure before/after and it lowered it about 1-1.5". My only concern is if it settles much I'm going to have problems with speed bumps. I'll try to get some pics posted this weekend.
Old 06-09-2017, 08:46 AM
  #3252
Bad324's Avatar
Since my 12 disc cd player took a dump figured I'd just upgrade the HU to a double din! Hoping to experiment and get some modernized climate control ***** fitted here soon too
Old 06-09-2017, 03:03 PM
  #3253
blackbyrd's Avatar
its amazing how much of a difference an updated headunit makes on these cars.
im curious what you figure out for the a.c *****
Old 06-09-2017, 03:11 PM
  #3254
Bad324's Avatar
I had found a photo a few months ago on a facebook group that had a double din and some round modern looking *****. When I posted if anyone knew what they came from the guy whose actual car it was chimed in and said he got them from a guy who made them and thinks they were these but modified on to the stockers somehow. I just got them in the mail and need to stop at a local shop that has some stock ***** and see all what I can do to make it work
http://www.ebay.com/itm/112272997936...%3AMEBIDX%3AIT
Old 06-09-2017, 07:13 PM
  #3255
blackbyrd's Avatar
There is a thread in the appearance section about installing them
Old 06-09-2017, 07:18 PM
  #3256
Bad324's Avatar
awesome I'll have to search and see if I can find it
Old 06-11-2017, 07:27 AM
  #3257
blackbyrd's Avatar
Finished leveling my B&B exhaust, and installed my shorter front swaybar end links . Then it's plugs and gas and maybe finally dial in my ridetech coilovers
Old 06-12-2017, 03:44 PM
  #3258
CoreyD's Avatar
IIRC some people are using Mazda 3 or 6 ***** for the HVAC controls. They looks pretty similar to the ones posted.
Got to install my new 555 G2's today. Also, changed out my DRLs for the millionth time. After these go out, I'm definitely switching to LED!
Only a little bald..
Old 06-12-2017, 04:07 PM
  #3259
JohnR's Avatar
Finally finished replacing all 10 speakers with a set from Kee Audio. A previous owner had replaced the 2 back seat subs with a pair of 5" plain speakers, and one of them wasn't working. I had to trim the door panel a little in order to get it past the new 6.5" speakers. I also put in some Fatmat while I was in there. Now it all sounds awesome again.
Next step is replacing the stock head unit with a Kenwood unit from Kee.
John
Old 06-13-2017, 07:39 AM
  #3260
hardtrailz's Avatar
I picked up a set of factory wheels for $100 to try and save.
A bit of water and 5 minutes with a microfiber did wonders. Can't wait til I get the time to really work on them and see if they will be saved.
Quick Reply: what did you do to your firebird today?
