Tr6060 electronic sensors and such
Hi all, I have a few questions.
I have a 2013 tr6060 in my 78 trans am mated to an ls6.
I'm going with a GPS Speedo, but I'm not sure what to do about the tachometer. I have 3.73 gears and aftermarket wheel/tire combo so a mechanical gauge is probably out of the question.
also what can I do with the existing harness on the tranny? Can I leave it off and simplify the harness? Will skip shift automatically be left out or will I need to eliminate it? Thanks
Does a 6060 even have skipshift ?
On older T56's just leave it unplugged.
and rev counter has nothing to do with the gearbox. What sort of signal did your old rev counter use ?
the original gauges were all mechanical, so I'm going to go gps for Speedo. My other question: if I leave harness unplugged, will it function properly? Without the skip shift, temp sensor, gear sensor...etc, will it operate correctly or will there be an interference of some sort?
thanks
Again dont know about the 6060..but on T56's simply leaving the skipshift unplugged removed it.
I would assume the 6060 is the same.
unless whatever ecu or control systems needs a trans temp reading...then I see no need for that. And what do you mean by a "gear sensor" ?
It's just a manual gearbox, it will do that job with no wires plugged in, other than if there is a reverse lockout as per older boxes.
![](https://cimg0.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/149834462059320295566_6e4955c4336ee289c53257a95d513965e7069070.jpg)
![](https://cimg5.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/1498344657359766498944_51ad58c90a9e5cbb7d0ec1cc048a76eed8e761a8.jpg)
I'm interested in the outcome. I am putting a 2017 LT1 with a TR6060 into a 1988 Camaro. There must be like 6 electrical plugs in the transmission. Other then the speedometer, reverse lights, and reverse lockout, do I need the rest? Do standalone harnesses plug into manual transmissions or just automatics?
As I do research, I am learning new stuff all the time. Tranny fittings and GPS Speedo are two new things. My next thing is the hydraulic line going from the master to the slave. I haven't seen many tremecs but the one I have has the slave on the right side. Isn't it usually on the left?
I used an adapter to go from -4 AN to the quick release of the slave cylinder, I found it on ebay
![](https://cimg1.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/1502592291374456109606_6ac3c022c1c1d0e706e0e9be5c9d775b7f4efacb.jpg)
![](https://cimg5.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/15025923239091056263177_98610adc3032d38bda1bb729c1b553ec8472dd64.jpg)
I used a wilwood clutch pedal
![](https://cimg7.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/15025923446162051380354_bea85b905b431ebd26f0690fcc645876975c5d5c.jpg)
Also used a 3/8-24 To -4 AN fitting to make it easy
