Tabs snapped off balancer...what now
Old 09-01-2017, 12:32 PM
blackfbird98's Avatar
Default Tabs snapped off balancer...what now
Before I get the "well had you put it on right" spiel , I have done this many times with no issue, the car has been sitting for 2 years outside and I'm sure had some play in this happening. With that being said while using my 3 jaw puller from summit racing two of the inside tabs of my harmonic balancer snapped off completely, I now have nothing to grab onto with the puller and the arms are too short for me to reverse them to try and grab from the outside. I got it to slip off maybe a 1/4 inch so could I just use a mallet and hit it from behind or is there another trick to get this thing off? I'm not worried about damaging the crank I am building a 6.0 and have a new crank I just need this off so I can take off the timing cover and recover the cam
Old 09-01-2017, 01:01 PM
vettenuts's Avatar
Got a photo of your current situation?
Old 09-01-2017, 01:10 PM
I'll post it when I get home from work
Old 09-01-2017, 01:53 PM
Floader's Avatar
Heating the hub with a propane torch helps out a bunch
Old 09-01-2017, 02:04 PM
Then hammer it off?
Old 09-01-2017, 02:43 PM
Floader's Avatar
you maybe able to heat it enough to hammer it off, or grind some notches in the dampener to get your 3 jaw to hold on. More than one way to skin that cat. But, with a little heat it will come off much better.
Old 09-01-2017, 08:09 PM
Here's what I'm dealing with...
Old 09-01-2017, 08:14 PM
Darth_V8r's Avatar
Drill a hole in each spoke and use a bolt type puller like a steering wheel puller or gear puller?
Old 09-01-2017, 09:35 PM
moekluse's Avatar
I have a huge jaw clamp what will fit around the pully. I'd use that and heat the balancer not the crank snout as the snout will expand into the balancer giving u even more trouble. Also, don't forget to pray lol
Old 09-01-2017, 09:40 PM
moekluse's Avatar
that's a pretty good idea but drilling through that thing would take forever. I wouldn't recommend a wheel puller as it's intended for much less force, and the bolt type puller from auto zone strips the threads with a substantial amount of force. Heat is derfinatly your friend
Old 09-01-2017, 09:56 PM
LS1MCSS's Avatar
Drill it, thread it, and use a regular balancer puller. It's cast so it will drill easier then you might think.
Old 09-01-2017, 10:04 PM
moekluse's Avatar
Incase that doesn't work,
Old 09-01-2017, 10:39 PM
Received 3,110 Likes on 2,425 Posts
THAT is one cool tool!
Old 09-02-2017, 08:34 AM
243's Avatar
I would try drilling about a 3/16-1/4" hole straight into the flange of the damper parallel to the crank snout and then try to split it with a sharp cold chisel.
Old 09-02-2017, 11:12 PM
LS1MCSS's Avatar
Damn.
Old 09-03-2017, 03:38 AM
LLLosingit's Avatar
I have a few local parts stores that loan tools for free (refundable deposit) Why not try to get a puller that will fit the outer ring? There is no way you can hammer it off.
Other option since you don't care about the crank would be to cut it off with a plasma cutter or oxy torch.
Old 09-04-2017, 09:17 AM
zmracing's Avatar
Did you ever get it off? Which method worked? I have never seen this so I just wanted to know how you got past it.
Old 09-05-2017, 12:31 PM
BlwnLs1GTO's Avatar
Do you mean to cut into the damper with a grinder? Kind of like how you remove an old hub? Because that's what I was thinking before you posted this.
If you can get a good size cut "Near" the crank and far enough back, you may be able to use that chisel to crack that hub all the way through.
Or, the big jaw puller is a great idea too. I'd actually try this first...With heat.
Old 09-05-2017, 06:07 PM
kingtal0n's Avatar
This reminds me of the episode where peter accidently switches the TV to input mode
(oh god, I hit input, we have to throw away the TV now...)
Don't throw away the engine. But you could always throw away the engine
Old 09-05-2017, 06:59 PM
moekluse's Avatar
Quick Reply: Tabs snapped off balancer...what now
