Speed Engineering True Dual Exhaust Kits!!
#682
This kit was built on a stock height car. Some users were okay after adjustments but still is a compromise if your particular area is terrible like my roads are.
Or you can actually respond to help instead of taking up space for rest of us to read through. Damn kids.
And don't worry about the rest of those guys. They the type to take selfies lol
#683
This thread blows my mind. I have to make a few comments.
First off, thank you speed engineering from making killer products at super low prices so more of us people with kids etc and average bank accounts can still mod and put food on the table.
EVERY aftermarket exhaust I've ever dealt with fit like **** if there wasn't a lot of effort put into it. My wife's SN95 mustang had about $1400 worth of x pipe and cat back on it (BBK catted x pipe and magnaflow stainless catback) and it hung real low and rattled and fit like **** because the installer wasn't very bright. I spent well over an hour on a lift rotating pipes for the best clearance and then putting a pole jack under the pipe and then tightening the clamps. After I was done, it wasn't perfect in my book but I could have spent more and got the same result. If it had cost less I would expect worse. This exhaust speed engineering is offering is no different in that regard and for $500 it looks and fits amazing (WAY better than I would expect for the price) as shown by people that went through the effort of taking their time to get it right. There could be an issue here and there, but that's the go fast game, especially with the first run of a product.
As stated earlier, every mod requires mods. If you aren't up for it you're in the wrong game. The most expensive parts require modification to fit in most cases as well. I've installed FAST products, Trick Flow, Nitrous outlet etc etc it all required some time tweaking.
EVERY LOWERED F BODY WITH AFTERMARKET EXHAUST HAS CLEARANCE ISSUES. If it doesn't it's because someone spent A LOT of time working with it to get it as high as possible. Even then, it usually scrapes. It's part of owning a lowered F body. I had lane's true duals on a lowered F body (some of the best ever made for these cars) and I scraped all over the place, I didn't care because I knew that's just the way it was and if I wanted it to stop I needed to spend more time under the car and raise it back up.
Finally. Again, thank you speed engineering, I'll be ordering some of your NBS headers as soon as things calm down financially and I can go back to modding my toys again.
#684
00pooterSS, you have just defined hotrodding! ESPECIALLY with exhaust systems! It is the very NATURE to have to twist, turn, jack, clamp, unclamp, readjust, reclamp, etc. AND repeat the above until it's right, maybe a half-dozen times or more until it is right. Patience is a rare virtue! lol
#686
Thank you 00pooterSS. Your comments are much appreciated. With that being said I wanted to give you guys a heads up as well. We are currently in the middle of a revision to the center section of our exhaust. With so many lowered guys out there we wanted to make sure our exhaust is as high as possible. The revision is not much, but it should allow for approx another 1/2" maybe a little more of clearance in the middle. We will probably have that revision in production within the next 6 months.
Thanks
Sean
Thanks
Sean
#687
Thanks
Sean
Thanks
Sean
#689
https://ls1tech.com/forums/generatio...l#post19761427
Take the measurement as seen in the 2nd pic and subtract 30 inches from it and that's going to be how much ground clearance you get. The lowest part of the speed engineering exhaust is the area just after the driver side header.
My measurements are 27 inches in the front and rear. What are yours?
#690
See my install here:
#692
Thanks
Sean
Thanks
Sean
#693
What would be good for Speed Engineering to develop is a Y pipe with dual cutouts on it as no one has one available atm for purchase. Something that has good clearance would be like the design of the pacesetter Y with cutouts in the locations as seen in the pics 1 and 2 below. It's not the best Y merge, but that doesn't matter because you will be running it with the cutouts open at the track.
Pic 1
Pic 2
My attempt at putting dual cutouts into the speed engineering Y pipe failed resulting in very bad ground clearance, so I put the cutout in the I pipe.
Attempt at dual cutouts in the speed engineering Y
Current setup - single cutout in the I pipe, Speed Engineering Y with no cutouts in it
#694
The height of the center section is only as good as the height of the pipes that go from the longtubes to it. I'm assuming you are talking about the whole Y pipe and not just the Y merge "section"? My car is at 27 inches off the ground (which some have reported as being stock ride height) and the lowest part of the Speed engineering exhaust isn't the Y merge, its the pipe that goes from the driverside header to the Y merge seen here circled in red. I get 3" of ground clearance, which is the same amount of clearance that the bottom of the MWC crossmember is giving me.
I meant the X pipe itsef, wich bends down after joining both pipes, as seen on the following picture:
#695
#696
Yes, our revision is for the true dual rear exit kit center section, not our Y-Pipe. We are trying to add as much clearance as we can for the lowered cars out there. I dont think we have ever had a revision on our y-pipe. All of our kits come pre-boxed, and will not be offered as individual sections unfortunately.
Thanks
Sean
Thanks
Sean
#697
Thanks
Sean
Thanks
Sean
#699
I've got mine up as high as it will go while still clearing the cross member and I'm getting 3" clearance. At stock right height, I'd get around 4" clearance. It's fine for me, but for those who are more than an inch lower than stock they may get even less ground clearance than what I got.
#700
Our true dual exhaust kits are finally in for the 1998-2002 F-Body's. Here are a few pics and links.
Thanks guys..
Sean
LS1 Camaro Firebird True Dual Exhaust (Axle Dump)
LS1 Camaro Firebird True Dual Exhaust (Rear Exit)
Thanks guys..
Sean
I have a MWC watts link, I should be good as far as clearance right?
