Gen IV Connecting Rods
Old 12-21-2017, 10:58 PM
SLWRDE's Avatar
Default Gen IV Connecting Rods
I have a LM7 5.3 with Gen IV connecting rods and pressed fit pistons. Would a set of floating pin pistons work with my connecting rods? If I can use these pistons is there anything else required for this to work. Thank you.
Old 12-22-2017, 11:42 AM
tjz450's Avatar
If I understand what you are asking, no. The wrist pin has to be retained by the C-clips in the pistons or by a press fit in the rod. I believe all gen IV rods are floating,
Old 12-22-2017, 12:05 PM
LS1Tech Premium Sponsor
tech@WS6store's Avatar
floating pin pistons like our 4.8 flat tops, 5.3 dished, or ls1 bore floatin pin pistons will work with a pressed pin rod. You just dont use the pin clips. Sometimes the rod may need a slight hone. OR you can also have the rod machined for a floating pin. Thats what im doing to a set of gen3 4.8 rods.
Gen4 rods will of course work with floating pin pistons BUT you cannot use press pin style (gen3) pistons with a gen4 floating pin rod.
Old 12-22-2017, 05:08 PM
00pooterSS's Avatar
If you have a gen 4 it should be a floating pin so yes you can use floating pin pistons
Old 12-23-2017, 04:52 PM
SLWRDE's Avatar
Thanks for all the help. I have a different 5.3 then most. Its a Gen 3 engine externally but a Gen 4 Internally. My Rods are Gen IV but my pistons are press fit not floating.
Old 12-23-2017, 04:55 PM
That is not possible.
Gen4 rods really werent "gen4" its just an easy way to label them. They started in 04 for the lq9 and a few others but every 05+ engine and every gm reman from around 2009 and up used them.
If that is how your engine came, then it never ran. The pins would hit the cyl wall on warmup.
Old 12-23-2017, 09:55 PM
Received 3,508 Likes on 2,162 Posts
Throw up some pics!
Old 12-23-2017, 10:38 PM
truckdoug's Avatar
i have seen two sets of these. one in my NA truck, another i sold on here for $85 a while back.
they are in fact just exactly what OP states. beefier Gen 4 type rods with a bushed small end and a pin that is press fit into the piston.
Homer_Simpson (12-06-2021)
Old 12-23-2017, 10:45 PM
truckdoug's Avatar
this is the only picture i have, from before I mailed the set i sold to the buyer. please look close at the pin area and not there is no clip nor provisions for one.
both sets came from 24x tooth truck motors
Old 12-23-2017, 10:54 PM
brandon6.0's Avatar
^^^ thats crazy! I havent seen any setups like that either. Thats new to me.
Old 12-23-2017, 11:00 PM
truckdoug's Avatar
yeah its an oddball for sure. denmah has seen a couple himself. calls them gen 3.5. all from 24x dbc NBS trucks.
the one in my NA truck has been a beast. a year of 18 psi on pump gas, no meth and now it pulls down 18mpg on the highway hauling yard debris haha
Old 12-24-2017, 07:06 AM
chevymec's Avatar
I just bought a 5.3 rotating assembly from an 05 truck and it has the dimple rods. I didn't notice it untill I got it all home.
Old 12-24-2017, 10:51 AM
KCS
KCS's Avatar
Are you sure the pin is press fit into the piston and not the rod? When I heard about these, it was the Gen IV rod that was machined without a bushing to have a press fit with the pin, same as the older rods, and then the pin still floated in the piston pin bore. I've never seen a set personally, just asking for clarification.
Old 12-24-2017, 12:19 PM
truckdoug's Avatar
nah i'm pretty sure it was pressed to the piston. there were no oiling grooves in the piston as seen here.
I did disassemble one and it had the normal gen4 type bronze small end bushing with a chevron shaped oiling groove.
Old 12-24-2017, 12:21 PM
What did it take to press it out?
Old 12-24-2017, 02:03 PM
truckdoug's Avatar
heat and a small bench-top arbor.
Old 12-24-2017, 02:43 PM
SLWRDE's Avatar
Sorry for the late reply but here you go.
Here are the Rods
Old 01-02-2018, 12:59 PM
cookseyb's Avatar
Hijack, Did you ever get your 6.0 finished?
Old 01-02-2018, 02:58 PM
SLWRDE's Avatar
Truckdog,
Do my piston look some what like yours did?
Quick Reply: Gen IV Connecting Rods
