Brace s366's?
Brace s366's?
Are s366's heavy enough to where they need bracing? I am running vbanded truck manifolds so basically just the vband clamp is holding it together. My motor is not solid mounted but I could make it if need be. My turbos are kind of far from the motor so I didn't want to brace them to the heads. Need ideas
You have to think as well, the further you get from the V-band the "heavier" they become due to leverage. Personally, I would at least put a rod on them to help support some weight, but if the motor rocks it could cause more stress than if they weren't braced.
Can you fab up a brace to the block somewhere to eliminate the rocking motion being detrimental?
Yeh I think I'm gonna look into putting some kind of limiter on to keep the motor from moving. Might do what you said and at least put a single rod on them to help support some weight
The weight of a turbo should never be hung off any pipework without any other support unless the manifolds are very compact and made from a sturdy material.
For a remote setup like that, the turbo must be mounted properly with no strain at all on any pipework.
Ok I kinda just went full retard on the brace lol they actually turned out pretty nice. Now I am going to put in a motor plate and rearrange my alternator and power steering pump. The snowball continues. . .
