Provide some sanity....Gen 3 vs Gen 4
Old 03-03-2018, 12:43 PM
ddnspider's Avatar
Default Provide some sanity....Gen 3 vs Gen 4
I was all set to buy a kit from ws6 store to do a rebuild on my LS6, see cam thread here:
https://ls1tech.com/forums/generation-iii-internal-engine/1892131-ls6-fell-my-lap-help-me-pick-cam.html
Just to be certain, I figured let's pull the pan and dig a little to make sure I don't need anything else before ordering. Well... It appears someone's been in this motor before. It's definitely an LS6 block...but it definitely has Gen 4 rods in it. From searching, you can't have Gen 4 rods without Gen 4 pistons. So I've got an LS6 block with gen 4 rods and pistons and what i believe to be an LS6 crank. When searching I can't seem to find a clear answer.....are gen 3 and gen 4 rod bearings the same? I know i need a new crank so trying to figure out my options right now and what I should be buying.
Looking around I can get a remanufactured ls1 crank with main and rod bearings for like 175, but can I even use the rod bearings? 2nd question is about piston rings. If we decide to replace them, is it just the factory 3.89x or whatever gen 3/gen 4 piston rings or are there differences. I can't seem to find people selling gen 4 stuff specifically so I'm confused. I build boost and tunes, not short blocks, so any help is much appreciated.
Old 03-03-2018, 12:47 PM
LS1Tech Premium Sponsor
tech@WS6store's Avatar
All LS rod bearings are the same.
The rings on ls1 pistons were standard rings and thats what comes in our kits. whether floating or pressed pin its the same ring set.
You can upgrade to a napier 2nd for a little more but be careful as alot of ring sets use a low tension oil and that is what helps agitate oil consumption and pcv issues. Our kit uses a std tension oil.
The 04 gto and 05 ctsv used that style ls1/6 setup with floatin pins. They also use the 2nd design head bolts and cam bearings. Also all gm reman engines from circa 2008 and up use the "gen4/2nd design" parts.
Old 03-03-2018, 01:02 PM
ddnspider's Avatar
That kit specifically says the HD pistons do not work with gen 4 style rods. Is that because they're floating not press fit?
Old 03-03-2018, 01:04 PM
ddnspider's Avatar
I'm also confused what this thing is because the head bolts I took out were the 1st design I believe because they had shorter outer bolts. I assume that means it can't be a gto or Ctsv.
Old 03-03-2018, 01:09 PM
I would double check your head bolts.
There is a period on our piston only description but it SHOULD say press fit pins will not work with gen4 rods. I will change that.
It does not say that in our complete rebuild kits though.
Old 03-03-2018, 01:12 PM
ddnspider's Avatar
Am I misreading this?
Old 03-03-2018, 01:13 PM
ddnspider's Avatar
I have gen 4 rods....and it says will not work with gen 4 floating pin rods which is why I'm confused.
Old 03-03-2018, 01:26 PM
It should say press fit design will not work with gen4 rods.
Below you see an option for floatin pins. We thought that to be self explanatory but I will modify the description to help.
Like i said if you look at the complete rebuild kit and not just the pistons you wont see that.
This is us telling you the floating pin option will work with gen4 rods though. Or any other floating pin rod that takes a .945 pin.
We will be using these pistons in the iron 5.7 and the 5.1l short stroke with either gen4 rods or modified gen3 rods.
Old 03-03-2018, 04:28 PM
ddnspider's Avatar
ok I think I follow. Now I need to figure out if this worth swapping pistons if I have gen 4 stuff. I should be tearing into the motor more on Thursday so should know then what the heck I actually have in there.
Old 03-03-2018, 05:19 PM
omc8's Avatar
I know you guys have it right , but what adds to the confusion for Alot of buyers is most other parts catalogs have 04 GTO as pressed pin with no options ,they are selling the wrong parts.
Old 03-03-2018, 06:25 PM
5.7stroker's Avatar
Just wanted to chime in and say shopping at ws6store has been great. I just ordered a magnaflow muffler and TSP Y pipe on Wed and I had both items on Friday and the price was cheaper than anywhere else.
Old 03-03-2018, 09:54 PM
Received 3,508 Likes on 2,162 Posts
Yeah guys, don’t be bashful to call these guys on the phone if something doesn’t compute. Tech department is spot on, and will get you fixed up quick.
Old 03-04-2018, 11:37 AM
Fyi our floating pin pistons will also fit on pressed pin rods, you just do not use the pin clips.
Old 03-04-2018, 11:49 AM
ddnspider's Avatar
Thats good to know. I saw your note about the price hike at the end of the month so I'm hoping to sort out exactly what I have and need within the next week or 2 and finally get the order done.
I'm considering pulling the motor that's in my SS and dropping it in the z28 that had the broken LS6. Since the LS6 has Gen 4 stuff, it should be pretty stout so I can turn the boost up on the D1SC.
Old 03-08-2018, 04:54 PM
ddnspider's Avatar
Now I'm thinking gen 3....opinions? The rod on the left is mine and the rod on the right is an ls3.
Old 03-08-2018, 05:07 PM
00pooterSS's Avatar
The rod on the left has a press fit piston/pin (gen 3), also the small end of the rod is noticeably smaller than the one on the right that's a floating setup (gen 4)
Turn the rods sideways, even more noticeable
Gen 3 on the right gen 4 on the left
Old 03-08-2018, 05:35 PM
The only thing you need to know is if the pins are press fit or floating. Dont get caught up in gen3 gen 4 etc.
Old 03-08-2018, 05:47 PM
ddnspider's Avatar
And I've got press fit so should be good to go. Finally got the motor torn down so I could check everything out. I'll be emailing you shortly.
