If you haven't tought much about the oil galley Barbell check this out!
Old 09-05-2017, 07:09 PM
  #81
Cwarta's Avatar
Crazy fast shipping
Old 09-09-2017, 06:08 PM
  #82
Kawabuggy's Avatar
I just got mine in today! Wanted to say thank you for the super fast shipping, and also this thing is beautiful! Great machine work whoever did it.
Old 09-11-2017, 10:29 AM
  #83
Gunters96lt1's Avatar
I got my barbell and oil pickup hold-down last Friday. Very pleased with both pieces.
Old 01-21-2018, 06:53 PM
  #84
computerz's Avatar
Finally installing mine. Beautiful little piece of machining!
Old 02-06-2018, 10:30 AM
  #85
LS1Tech Sponsor
saccitycorvette's Avatar
Thank you for your business and kind words!
Christian
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 04-14-2018, 11:52 AM
  #86
CoreyD's Avatar
Installed mine last weekend! Nice little piece!
Old 04-14-2018, 02:26 PM
  #87
LS1Tech Sponsor
Thanks Corey for your business and the kind word and photo!
Christian
Old 05-08-2018, 01:52 AM
  #88
LS1Tech Sponsor
We keep all of our Billet Oil System Improvement parts in stock for when you're ready to keep unfiltered oil out of your bearings and lifters.
http://www.saccitycorvette.com/OilSy...provement.html
Thank you!
Christian
Old 05-08-2018, 11:23 AM
  #89
1FastBrick's Avatar
I noticed the 3 in 1 kit. Out of curiosity, will you be offering all 4 items as a package deal in the future for people doing new builds?
Old 05-08-2018, 08:08 PM
  #90
LS1Tech Sponsor
Hi FastBrick,
Just added!
Thank you,
Christian
Old 11-19-2018, 04:12 PM
  #91
LS1Tech Sponsor
If you have your Rear Main Seal Cover off, you have easy a access to your barbell. This is a inexpensive worthwhile product that keeps unfiltered oil out of your bearing and lifters.
LS and LT1 lifters have tiny needle bearing in the rollers, small particles getting in these bearing greatly reduces there life especially with cam swaps that use heavier valve spring pressures that apply more pressure to these bearings.
Top engine builders like Texas Speed and WS6 Store use our barbells in there engine builds.
Thank you
Christian
Old 03-11-2019, 02:01 AM
  #92
DietCoke's Avatar
Originally Posted by saccitycorvette
Don't let unfiltered oil flow through your new engine build! In stock ready to ship!
Stop using this as a selling point. Oil is bypassed by design. This does not stop unfiltered oil.
Old 03-11-2019, 04:25 PM
  #93
Tramminc's Avatar
Originally Posted by Mercier
Got mine yesterday. Nice piece and fast shipping!
Thanks!
The shaft is not beveled as advertised. It's flat like the factory.
Old 03-11-2019, 04:45 PM
  #94
Received 3,110 Likes on 2,425 Posts
The factory barbell is plastic. The bevel is not really necessary for it to function as it is supposed to.
Old 03-11-2019, 10:10 PM
  #95
LS1Tech Sponsor
Hi Tramminc,
The packaging you are showing tells me it was purchased quit while ago, like in 2017. It is identical to the updated ones except for the taper.
Here is how we have been packaging them for almost 2 yrs even before the taper.
Thank you,
Christian
Old 03-11-2019, 10:19 PM
  #96
LS1Tech Sponsor
Hi DietCoke,
You need to take another look at what the Barbell does. Even the biggest LS engine builders like Texas Speed use our barbells in their builds because they know the OIL DIVERTER (barbell) is supposed to "divert" the oil
down through the filter! Any oil that gets by the barbell is not filtered! GM is ok with a certain amount of unfiltered oil going through the engine but we aren't.
Thanks
Christian
Old 03-11-2019, 11:09 PM
  #97
DietCoke's Avatar
Hi DietCoke,
Thanks
Christian
Sure, divert it to the oil filter so it can get bypassed there, instead. Increasing volume to the filter doesn't increase volume filtered.
Old 03-11-2019, 11:26 PM
  #98
LS1Tech Premium Sponsor
tech@WS6store's Avatar
Getting rid of 1 way guarantees more oil will get filtered. Plus artificial pressure loss.
Thats not a bad thing. The other pressure bypass works differently. Its not always on like the barbell is.
Ive pulled apart so many ls engines that had issues and the barbell rows had pieces of trash and bearing material stuck in them you can only imagine what doesnt get caught. Its a constant "leak" also
Old 03-12-2019, 12:15 AM
  #99
LS1Tech Sponsor
Why would it get bypassed if the filter is not plugged?
WS6Store gets it and they do a lot of LS engine builds using our Barbells!
Thanks
Christian
Old 05-28-2019, 12:15 AM
  #100
LS1Tech Sponsor
Thank you everyone for all your business!
Our Billet Oil Improvement Parts are in stock ready for same day shipping!
Christian
Quick Reply: If you haven't tought much about the oil galley Barbell check this out!
