Preliminary Dyno Results from LSX Intake - Courtesy of MTI!
Old Jan 14, 2004 | 02:29 PM
2000SS's Avatar
Default Preliminary Dyno Results from LSX Intake - Courtesy of MTI!
Inital Results: 7.4 HP gain over an LS6 Intake on a 427 CID F-Body.
This was the 78MM version with ported stock TB, bolted on with no changes to tuning or anything else on the vehicle.
We'll continue the fine tuning this afternoon and post more results as we generate then.
- Wayne, David and Jayson at Motorsport Technologies
Attached Thumbnails Preliminary Dyno Results from LSX Intake - Courtesy of MTI!-fast.jpg
Old Jan 14, 2004 | 02:32 PM
Sheomet's Avatar
How much less would that be on a 346 LS1? Those results seem pretty disappointing to me for the cost.
Old Jan 14, 2004 | 02:33 PM
Stew w/92&00's Avatar
interesting....
Old Jan 14, 2004 | 02:35 PM
Colonel's Avatar
Weird, we have one thread where it picked up 13 RWHP on a stock heads/mild cam car and another where it only picked up 7 RWHP on a big CI engine.
Old Jan 14, 2004 | 02:36 PM
Cobraeater's Avatar
Isn't the 90mm intake recomended for bigger than 346ci?
Old Jan 14, 2004 | 02:38 PM
2000SS's Avatar
We chose to test the 78mm version first as we're waiting on the 90mm TB to be released.
Thanks.
Old Jan 14, 2004 | 02:43 PM
Nine Ball's Avatar
LS1Tech Co-Founder
I'm betting the throttle body size is the main restriction on the big 427ci engine. Also, this 427ci engine has a relatively small 236/236 cam in it.
Tony
Old Jan 14, 2004 | 02:44 PM
gomer's Avatar
Any plans to do a stock cube car today or tomorrow?
Old Jan 14, 2004 | 02:47 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Old Jan 14, 2004 | 02:50 PM
Tally TransAm's Avatar
Originally Posted by SouthFL.02.SS
Old Jan 14, 2004 | 02:58 PM
Colonel's Avatar
Jayson tells me they'll be trying out some larger TBs (I volunteered a BBK I have laying around there somewhere) to wring some more HP out of this intake.
Old Jan 14, 2004 | 03:01 PM
Fireball's Avatar
was the dyno testing done on the same day like it was done at Thunder?
DONAIMIAN's Avatar
Yea hopefully with the bigger TB it will make bette numbers or else its gona be some pissed of people that pre-ordered the intakes.
Old Jan 14, 2004 | 03:03 PM
Scalpel's Avatar
I'll cancel my order if that's all it provides on a 427 after all the bugs/TBs are utilized, etc.
Old Jan 14, 2004 | 03:04 PM
The Juggernaut's Avatar
can the 78mm intake be hogged out to use a BBk 80 mm TB without the reducer?
DG Gordon's Avatar
7.4 hp is very disapointing. Especially on that motor. I would have expected that from a stock motor and the more power the more hp is gained. Maybe this will drive down prices!
Old Jan 14, 2004 | 03:07 PM
Fireball's Avatar
I agree with tony. big motors take alot of air and I'm betting that the TB is a large restriction at that point. For small CID cars with ported heads you see a massive flow drop in the intake ports once you bolt on a LS6 intake. if some of this flow is restored with the LSX intake, power gains can be exceptional (if the TB doesn't pose a restriction yet)
Old Jan 14, 2004 | 03:13 PM
2000SS's Avatar
we will be testing stock cars and H/C cars tommorow and Friday.
thanks
Old Jan 14, 2004 | 03:26 PM
pimpmaro's Avatar
It may only be 7.4, but it was also said that there were no changes to tuning. I wonder what that would change to with the 90mm TB and having it tuned for that intake?
Old Jan 14, 2004 | 03:38 PM
Nickn20's Avatar
I think to be truly fair to FAST, on a motor like this is to use the 90mm TB version AND port match the intake to the intake port of the head, I am sure they need it!!! then get some numbers for us!
