*** WARNING - StopTech/Centric Stainless Steel Brake Hoses *** Read first
However; it is very important to change the orientation of the hose on the caliper to avoid serious damage and complications when installing these hoses. They cannot be installed in the stock orientation, aligned to the recess in the back of the caliper, due to the thickness of the hose body around the attachment block. The hoses must come off the caliper at an angle so the thicker, black rubber/plastic hose body is not in contact with the caliper. (If the body touches the caliper, the attachment block will not sit flush on the caliper, will not seal, and will not allow the banjo bolt to go into the caliper straight.)
See these threads for complications if the hose is installed in the stock orientation:
https://ls1tech.com/forums/suspensio...p-leaking.html
https://ls1tech.com/forums/suspensio...0-62001-a.html
This is where it comes off on my 95, when we try to attach it to the caliper the turm radius goes to crap and would potentially snap the lines
