Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Shark Gray 2000 SS build
Old 01-19-2018, 12:54 PM
LaBLKv6Z's Avatar
Default (SmokingAsphalt) Shark Gray 2000 SS build
I'll edit this first post to keep up with the current status of the car.
*12-3-2020: New best 1/4 mile: 10.95, 1.78 60' @ 131 MPH, removed the stock style shocks/struts, will be replacing with coil overs.
*10-23-2022: New best 1/4 mile: 10.75, 1.64 60' @ 132 MPH, single adj coil overs up front, 4 way shocks rear, 80lbs heavier.
*2-5-2023: New best 1/4 mile: 10.73, 1.67 60' @132 MPH, same suspension as previous
LS3 block- 4.070" bore
Manley 4340 Forged Steel 4.100" Crank
SCAT 6.125" I-Beam rods
Manley 2618 Forged -7cc flat top pistions
GM oil pump
Ported (by myself) 821 heads
Stock GM replacement valves (hollow intake)
BTR dual platinum springs .660" lift with steel retainers
Johnson reduced travel race lifters 2116LSR
TSP Cam 243/255 .621/.619 111 LSA
TSP 2"primary to 3.5" collector long tube headers
Meziere 300 Series Electric water pump
T-ROD MOD LS3 intake manifold (done by myself)
92 MM TB
Siemen Deka 80lb injectors, LS3 fuel rail
1/4 mile best: 10.95, 1.78 60' @ 131 MPH
__________________________________________________ __________________________________________________ __________________________________________________ ________
1-19-2018
*Just an update guys, last week of Dec 17 I spun piston rod bearing #3 while doing a burnout at the drag strip. Since then I've dropped the engine out of the car and completely disassembled the block. I parted out and sold pretty much the complete engine.
What's going on guys? This will be the build thread for my 2000 Camaro SS M6. I'll add more information as I go, pretty much I'll be working on this on my lunch breaks.
I purchased the car in November of 2016. It had a couple of bolt ons when I bought it, TSP 1 7/8" longtube headers, SLP lid, Strange S60, 4.10 gears, Monster stage 2 clutch, Frost tune.
The previous owner had the car painted Shark Gray Metallic, the original color was Navy Blue Metallic. Shortly after buying the car, I put it on the dyno at a local shop's winter dyno day. Car put down 330/368 on the Dynocom dyno.
Jessemess (11-10-2020)
Old 01-19-2018, 03:49 PM
HCI2000SS's Avatar
Love that color
Old 01-22-2018, 05:19 PM
LaBLKv6Z's Avatar
Originally Posted by HCI2000SS
Love that color
Thanks, it really stands out at car meets.
Old 01-22-2018, 05:34 PM
LaBLKv6Z's Avatar
After going to the track and making some passes, I decided to clean up under the hood. There was still some areas behind the bumper cover that showed to be NBM. So I stripped the fenders off and decided to do some weight reduction along with the wire tuck mod. After, I degreased everything, I masked off the engine and body, then painted the frame horns and strut towers.
Old 01-23-2018, 05:20 PM
LaBLKv6Z's Avatar
Removed the front bumper support and foam. Made an aluminum bracket to keep the bumper cover solid.
It's about a 50 minute drive to the closest drag strip. The car was a lot of fun with the basic bolt ons. Averaged low 13's at 108mph.
Old 01-24-2018, 12:56 PM
LaBLKv6Z's Avatar
After owning the car for about 4 months and going to the track 3 times I was ready to start adding power. The Dorman LS2 intake was released so I decided to give it a try.
At first, I just planned to swap the intake manifold and get a dyno tune but decided to take the next step and go HCI. I've had great experience with Texas Speed in the past and always wanted to try the MS3 camshaft. I ended up ordering the PRC Stage 2.5 LS6 heads, MS3 camshaft and most of the supporting stuff from them (LS7 lifters, LS2 trays, timing chain set, Melling Oil pump, etc).
Dorman LS2 intake bottom side.
Untouched Dorman LS2 intake ports.
Dorman LS2 intake port with the step removed.
The tear down, look at the amount of crap under the intake.
Also bought the Speed Engineering 3" full dual exhaust kit which also just came out at the time.
New LS6 valley cover.
Stock heads removed. Notice the blue firewall.
Old 01-24-2018, 01:39 PM
HCI2000SS's Avatar
Have you ran it at the track with the HCI?
Old 01-24-2018, 05:06 PM
LaBLKv6Z's Avatar
Yes, I went to the track multiple times with the HCI setup and ran low 12's at 119-120 mph. Had a couple of 12.0s but never got into the 11's. 60' times aren't consistent yet.
Old 01-24-2018, 05:11 PM
HCI2000SS's Avatar
Sounds exactly like mine lol. 12 flat at 120 with a 2.0 60ft. Plus a 3850 lb raceweight doesn't help lol.
Old 01-24-2018, 05:20 PM
LaBLKv6Z's Avatar
Nice! You must be putting down more power. Mine weighs in at 3400lbs. I'm shooting for 10's now with the next stage of mods since I spun a rod bearing last month.
Old 01-24-2018, 05:34 PM
HCI2000SS's Avatar
Not really sure on my power, but our builds look very similar. Mine without me in it is 3650 lbs with a full tank of gas and full nitrous nitrous. The iron block adds a good 100 lbs so that's not helping lol. So what are your next rounds of mods?
Old 01-24-2018, 05:48 PM
LaBLKv6Z's Avatar
I gotcha, my car is 3585 with me in it. Next round of mods will be TSP Darton sleeved block, LS7 type CNC'd heads, spec'd camshaft, and all of the supporting components.
Old 01-24-2018, 05:54 PM
HCI2000SS's Avatar
Very nice! That's some serious upgrades. I went the cheap route and slapped on a 150 shot lol
Old 01-25-2018, 05:54 AM
LaBLKv6Z's Avatar
Nothing wrong with that, I'm shooting to trap high 130's low 140's in the 1/4.
Old 01-25-2018, 12:06 PM
LaBLKv6Z's Avatar
The following are images I took of the progress when installing my HCI setup.
LS7 lifter on the left.
PRC LS6 stage 2.5 heads
Looks like it'll flow nicely.
LS2 timing set.
New Melling oil pump and timing set installed.
Straub trunnion upgrade.
New brass bushings installed.
New heads going on.
Test fitting the Dorman LS2 intake manifold, no issues.
Old 01-25-2018, 12:16 PM
LaBLKv6Z's Avatar
WARR 92 MM TB fits great on the Dorman LS2 Intake.
Painted the valve covers GM Hugger Orange.
Valve covers on.
Clearance issue between the 92 MM TB and stock LS1 water pump.
Hit it with the dremel.
Most ppl just plate of the rear vent ports on the head. I decided to keep mine.
First set I had FIC 42 lb injectors, but Steve @ Frost tunes advised against them. So I just used them for mock up.
Angle torque tool I used to torque the head bolts down to spec.
Old 01-25-2018, 12:23 PM
LaBLKv6Z's Avatar
Decided to run my MAP sensor up front.
All buttoned up under the hood.
No trap door mod on this car.
Installed the Racetronix pump along with the hot wire kit.
Bought grade 8 bolts (left) to replace the weak bolts(right) supplied with the Speed engineering 3" dual exhaust.
Almost all lined up, not too bad installation.
This was installed with a UMI Tunnel mount Torque Arm.
Ready to hit the pavement. Only took 2 weeks working on it after hours.
Old 01-25-2018, 12:27 PM
LaBLKv6Z's Avatar
First cruise after the HCI install still on Mail tune from Frost.
Fast 36 Ib injectors installed.
Catch cans came in.
Notice where I installed them?
And it works.
Got it dyno tuned, baseline was 450 on the mail tune. Reading on the high side but I did baseline on the same dyno months ago so I know how much I gained.
Time for some new wheels.
Old 01-26-2018, 08:52 AM
KyleLanter's Avatar
Cool build man keep it up.
Old 01-26-2018, 12:15 PM
LaBLKv6Z's Avatar
Thanks man.
Quick Reply: Shark Gray 2000 SS build
