Big cam
Old 02-22-2018, 05:48 PM
Lsnewbee's Avatar
Default Big cam
So I've worked my way up from baby cams now its time for a donkey dick cam (246/250 627/630 112+3) so I can say i tried all before next year's plan of going boosted. Plan is for it to go in saturday I have all supporting mods hand ported 799s, 3.73 rear 10 bolt, will get more gear when that lets go. 6 speed car. What do you guys think I should get power wise. This is not a DD
Old 02-22-2018, 05:52 PM
HCI2000SS's Avatar
You want to put this cam in a stock LS1 with ported heads?
Old 02-22-2018, 06:03 PM
Lsnewbee's Avatar
Yes its Just stock bottom end with arp rod bolts everything else has been upgraded to support the cam. What is the problem with the cam its not much larger then the trex which was designed arou d stock heads
Old 02-22-2018, 06:06 PM
HCI2000SS's Avatar
That is a bit bigger than the t-rex cam. I seriously don't see it clearing the stock pistons.
Old 02-22-2018, 06:10 PM
Lsnewbee's Avatar
If it doesn't clear then it doesn't clear they sell tools to flycutt everyday lol. I'm not trying to be a dick in any way so please don't take it that way.
Old 02-22-2018, 06:16 PM
HCI2000SS's Avatar
Ok if you don't mind going through the process to make sure it clears then that's your choice. That cam will be a dog down low on your setup with just power at the very top end. A proper sized cam on the same setup would outperform it. You do realize this right?
Old 02-22-2018, 06:23 PM
ddnspider's Avatar
Complete waste of time and money for a setup that will get stopped by a properly designed setup a cam that has 20 degrees LESS duration.
Old 02-22-2018, 06:43 PM
Lsnewbee's Avatar
Being every cam should be checked before being installed for ptv is no trouble. How are you so sure that a smaller cam will out run it. just askin. It has been proven before that big cams make big power good track times. What part about that cam and my setup will not work right together. I'm not scared to turn 7000rpms
Old 02-22-2018, 06:48 PM
HCI2000SS's Avatar
It's been shown time and time again what cans perform best on these motors, anything that's significantly out of that range has been proven to be slower. Don't take my word for it. Search around and you'll see. Not trying to be harsh and whatnot, but rather trying to help you from making a big mistake
Old 02-22-2018, 07:06 PM
Lsnewbee's Avatar
Ok well already got the cam on the way it doesn't cost anything but time to install worst that could happen i don't like i put my old cam back in. Its only money lol. I like to try different things not copy everyone else so far it's working last cam made 400hp 392tq at wheels got this cam pretty cheap. This cam was specd to be in a ls1 as a max effort cam and ran low 10s
Old 02-22-2018, 07:21 PM
Lsnewbee's Avatar
I'm not arguing with any of you guys you may be right but u could also be wrong not all cars are the same nore are the setups. Just giving it a shot all I asked was whats your thoughts for power numbers
Old 02-22-2018, 07:26 PM
SoFla01SSLookinstok's Avatar
Cam is hefty. What intake manifold, headers/exhast system, is on car? Hard to guess dyno numbers.
Old 02-22-2018, 07:32 PM
Lsnewbee's Avatar
Obx headers true dual exhaust with x pipe rear exit no cats 96mm typhoon. Intake with a 92mm Nick Williams throttle body the intake will be upgraded very soon not the greatest design
Old 02-22-2018, 07:36 PM
ddnspider's Avatar
Do the heads even flow well at over 600 lift? They're 799s not 243s or aftermarket castings. Needs a fast 102 or MSD intake, more gear and a real rear end and shifting at 7500 to make that cam work. Got a clutch that can handle 6k clutch dumps?
Old 02-22-2018, 07:37 PM
HCI2000SS's Avatar
Throw in a 4.30 or 4.56 gear and it might help some lol
Old 02-22-2018, 08:02 PM
My opinion ,of this cam, is pretty much right with the others in this thread. Basically that a cam, not as big, would make at least, or more, average power in that rpm range. Bet that thing would want more than 7k. No cam designer here but I would think about a single plain with that cam maybe? Also thought of the 4.56 rear gears.
Only one way to find out.
Old 02-22-2018, 08:14 PM
Lsnewbee's Avatar
My opinion ,of this cam, is pretty much right on with the others in this thread. Basically that a cam, not as big, would make at least, or more, average power in that rpm range. Bet that thing would want more than 7k. No cam designer here but I would think about a single plain with that cam maybe? Also thought of the 4.56 rear gears.
I said in my first post gears were coming and I. Only out the cost of the cam which isn't much atleast I can say i tried it. What's the worst that could happen it lets go i got a spare motor lol
Old 02-22-2018, 08:16 PM
Right on. It'd be cool to see the outcome. Make sure to post up results.
Old 02-22-2018, 08:18 PM
HCI2000SS's Avatar
You'll also need a good tuner to make that cam drive "somewhat" decently
Old 02-22-2018, 08:41 PM
Darth_V8r's Avatar
Received 1,836 Likes on 1,145 Posts
I am curious how this goes but I think you are going to be disappointed unless you run it 12:1 compression. I really think that for max effort on a 346, 237-242 intake and 242-246 exhaust is the best spot. Look at the top performing 346s and that is what they run.
It will def sound cool at idle!
