Any lowering springs for 02 ss convertible besides my bmr?
Old 04-21-2019, 08:18 PM
bad_408_vert's Avatar
Default Any lowering springs for 02 ss convertible besides my bmr?
So my bmr 1.25” are awesome but I suppose due to extra weight of convertible the springs have more weight on them and car sits lower than I need because front air dam bottoms out way too often.
what are other springs other than oem that I could use?
is this normal or possible install error . Shocks are Koni str wheels are 17x9.5
Old 04-21-2019, 09:38 PM
Chris Paveglio's Avatar
Strano springs, IIRC ~0.75 -1.0 inch? Call him to see what he says about lowering amount.
Old 04-22-2019, 07:28 AM
01Z0H6's Avatar
I ran the Stranos on my Vert...
Old 04-23-2019, 12:42 PM
hardtrailz's Avatar
I been thinking of the BMR myself. The strano rear almost looks lower in those pics.
Old 04-26-2019, 04:19 AM
chuckclanton's Avatar
SLP Stage 11
Old 05-29-2019, 06:50 PM
GHall8788's Avatar
Strano, all 4 here, this was when i had stock shocks.
Old 05-30-2019, 06:14 AM
ThoR294's Avatar
strano
Old 05-30-2019, 10:03 AM
hardtrailz's Avatar
That is an odd looking convertible
Old 05-30-2019, 12:15 PM
GHall8788's Avatar
I don’t get it
Old 05-30-2019, 12:27 PM
hardtrailz's Avatar
That was fairly obvious
Old 05-30-2019, 04:50 PM
GHall8788's Avatar
Okay.
Old 06-05-2019, 07:04 PM
Taprxxt's Avatar
I had the Eibach ProKit on the same Koni's you have and it was definitely not that low in the front (see below pic, Eibach claims 1.5 drop in the front). Granted I don't have a vert but that still seems really low for the BMRs even with the extra weight.
Just switched to the UMI/Strano/Afco coilovers for the adjustment options. Drove the car only once as I installed the kit this past weekend but I was definitely happy with the result.
Old 06-10-2019, 06:11 PM
I put SLP stage 11 on my 2000 SS Convertible. The front is close to stock height, but the rear is 26 7/8 in. Sits fairly level.
Old 06-19-2019, 10:47 PM
Thanks for replies and info.
I ll measure the height and take pictures.
Im just not happy with how limited driving I can do at the moment, because either I drive very slow to avoid damaging the air damn or have to be very selective on when to take car out.
Old 06-22-2019, 04:11 PM
38DD2436's Avatar
I'm installed 4 Strano's. I really don't like them. Made my SS sit higher in the front and low in the rear. I called him and told me the fronts will settle. Been over 2 years and no change. Do you think he will take them back? The Eibachs are a perfect match for my 98. The car sits perfect. Extremely happy!
Old 06-23-2019, 08:59 AM
99Silver6.0's Avatar
My Stranos dropped the car 1.25” all the way around. No freaky front higher than the back stuff. Each fender lip is at 26.50” give or take 1/8”-1/16” of an inch.
Old 06-23-2019, 09:26 AM
JimMueller's Avatar
You could look into coilovers and/or weight jackers and then set the height where you want it instead of accepting whatever the spring happens to give you.
Old 06-26-2019, 03:46 PM
xny1989's Avatar
Not fer nuthin', but the front of your car looks way low. I've got Strano's on my vert with the Koni str.t's. I do occasionally scrape the front air dam, but only on steeper driveways. You can probably see the other cars on here with lowering springs are sitting higher in the front than yours. Is everything in the front suspension OK? The suggested coil overs should give you the height adjustment you may need.
Good luck
Old 07-02-2019, 07:31 PM
Update on measurements.
Front fender lip (L & R) is 25” if measured from the ground.
Rear fender lip (both sides) 26”.
All tires are at 35 psi.
At time of install, front sway bar was also installed.
Car overall is much better to drive but I have nothing to compare it to besides when stock shocks that were on there.
Any idea what to check ? Nothing loose or rattles.
On harsh bumps , it does sound like shocks compressed 100% and they hit the inside of shock tower.
Are there any insolators or bump stop type part that I maybe missing for the front?
Old 07-03-2019, 01:41 PM
xny1989's Avatar
With my Strano's and Koni's, and 275-40 17 tires and wheels, I measure front at 26.3" at the front.
