Should I loop the power steering rack or leave it open?
Old 05-18-2019, 01:31 PM
cornfedlsx's Avatar
Default Should I loop the power steering rack or leave it open?
1998 Camaro power steering delete
should I loop the rack with fluid in it?
should I loop the rack with no fluid in it?
or
should I not loop it and plug it?
yes I know I should get a manual rack... I will. This is only for a year or 2.
Old 05-18-2019, 03:34 PM
Floorman279's Avatar
i dont think you can do this......the fluid still has to overflow somewhere when turning the wheel
Old 05-18-2019, 04:28 PM
01CamaroSSTx's Avatar
Received 1,786 Likes on 1,293 Posts
I'm thinking that converting to manual rack would also mean getting rid of tilt steering as manual steering can be hard on the components. If I'm wrong then chime in and let us know what all you did to convert over.
Old 05-18-2019, 05:29 PM
cornfedlsx's Avatar
Guys.. this has been done like a million times. But I hear multiple people say different things on whether to leave it empty or loop the lines.
Old 05-18-2019, 05:57 PM
pdxmotorhead's Avatar
If you leave them open the rack will injest crap and die, some racks can lock if you just plug the holes, so I'd loop it with a breather.
The bigger question, why take the pump off? need room or something?
Old 05-18-2019, 06:50 PM
cornfedlsx's Avatar
Taking it off off because I don’t need it. Car maybe sees 200 street miles a year, and then rest is going in a straight line.
Where and how how would I put a breather on it if I’m looping it..
Old 05-19-2019, 06:23 PM
Stitch1717's Avatar
Anytime i've seen guys do that they seem to loop it so it doesn't make a mess driving it around none were fbodys, mostly 240 guys with ls swaps, or rx7 guys with ls swaps.I would fill it with fluid and bled it the best you can then loop em without a breather.
Old 05-19-2019, 07:32 PM
Looping meaning connecting the two hoses together?
Old 05-20-2019, 07:32 PM
Jtm2085's Avatar
I left mine open. Been that way for awhile now with no issues
