08 c6 ls3 ticking noise
Old 03-04-2023, 06:26 PM
LQ350Z's Avatar
Default 08 c6 ls3 ticking noise
Hi guys so I'm having a problem with my ls3 with a ticking noise
what i had already done before the ticking came:
lsr cam don't remember the specs
660 lift dual valve springs
trunion upgrade kit
ls7 btr lifter
After like 1k miles the ticking started
What ive changed when it started the ticking:
new king performance rod bearing old ones were find no deep scaring old bearings looked kinda new
and new gm oem exhaust manifold gaskets
new pushrods and checked the preload I'm around 90
new ls7 btr lifter
I'm still hearing a ticking noise u can't hear it to much from outside but inside the car it's very loud kinda like a bad lifter but this is my second set thinking that my old ones were bad but still has the noise. Everything I've done was because of the ticking trying to get rid of it gets louder from 1.5k to like 4k then the pitch stays the same the ticking does speed up with the rpms I can hear it louder from the shifter tunnel than from the engine way super weird I did have my Trans cooler line break and drove I think like 2 days and the Trans was dry refilled it with new oil all gears go in and stuff but for sure the noise is coming from the engine side I'm stumped does anyone have any idea what it could be
Old 03-04-2023, 06:33 PM
01CamaroSSTx's Avatar
Received 1,879 Likes on 1,356 Posts
What trunnion upgrade? You should be able to determine which rocker arm is ticking by taking a piece of hose and putting it to your ear while you run it along the top of each valve cover. Don't rule out an exhaust leak as they sound similar to a lifter ticking.
Old 03-04-2023, 06:51 PM
LQ350Z's Avatar
I changed everything pretty much an still has the same ticking new lifter exhaust gasket and pushrods thought it was maybe a bad rod bearing but when i changed them they were all in new condition pretty much
Old 03-05-2023, 09:40 AM
LQ350Z's Avatar
Anyone got any ideas what I could be or I should check before taking it to a mechanic?
Old 03-06-2023, 12:40 PM
grinder11's Avatar
Received 1,005 Likes on 715 Posts
You may have nothing to worry about. I've NEVER heard a quiet LS engine yet. The injectors firing away can mimic a lifter tick. I have a persistent one in my built LS7, and it's had 3 sets of lifters in it. Only does it at 2,000rpm, and only on the first start of the day. Yes, I'm running some pretty stiff dual springs on LS7 lifters, which is probably a factor. It takes over 5 minutes before it stops, and doesn't do it at all, at any time, from idle to 1,800rpm. Once 5 minutes goes by, it doesn't do it again all day. 45,000 miles on the engine, runs great, uses and leaks no oil. I'm done chasing it.
Old 03-16-2023, 05:57 PM
LQ350Z's Avatar
Hi guys added some videos to YouTube so u guys can hear it or might know what it is
Old 03-17-2023, 04:55 AM
Jimbo1367's Avatar
Pull off a VC and start it. I would imagine you should be able to find something.
the 1st video didn’t sound too bad, the second one definitely sounds bad
Old 03-17-2023, 12:10 PM
LQ350Z's Avatar
i did that after i installed the new lifters because i was still hearing it they all move up and down the same nothing out of the ordinary
Old 03-17-2023, 12:17 PM
Sounds like valvetrain noise to me. No metal shavings in the oil or filter?
Stay away from Comp trunnions.
Old 03-17-2023, 12:26 PM
LQ350Z's Avatar
Nope I even removed the rockers and checked them for sticking they were all smooth rocking down and up that's why I'm stumped at what it could be I opened the vc and the sound pitch was still the same didn't get louder from opening the valve covers
Old 03-17-2023, 12:36 PM
LQ350Z's Avatar
I'm starting to think maybe it's the piston wrist pin but no one has a video of on going bad to see how the sound is for reference me like an idiot didn't check them when I swapped the rod bearings 🤦‍♂️ and dropping the oil pan was a mission lol
Old 03-17-2023, 12:40 PM
That's definitely valvetrain noise. You can also use an engine stethoscope or large screw driver to listen with in order to pinpoint the cause of the noise. Could be coming from an exhaust valve or an intake valve but I'm leaning more to an exhaust valve. The valves can make quite a bit of noise as they're cloing on their seats and it's even more noticicable with headers. Try listening to each primary to see if you can pinpoint where it's coming from.
Old 03-17-2023, 12:45 PM
Here's a clip of a stock LS3
Old 03-17-2023, 01:13 PM
LQ350Z's Avatar
Yup i actually have another ls3 c6 but everything is stock minus the axleback that has the valves open it does have that type writer sound very minimal.. the thing is sounded that that one but then the ticking started on the passenger side that u can tell it apart from the rest of the type writer sound
Quick Reply: 08 c6 ls3 ticking noise
