Power steering fluid always nasty
I do the reservoir flush every year by myself to save some money and trips to the shops. I've had no power steering issues for over 20 years so apparently this 'el cheapo' maintenance works OK but it sure gets nasty over the course of a year. I realize I am always mixing in the new with the old but it never seems to get clear or even light colored. I finally took a photo of the old compared to the new I put in. Yeah, I guess I should have the whole system flushed professionally but I've gone this long so I'll probably keep doing the same routine until it breaks or starts leaking. I use the good old turkey baster method. A strange tool in the tool cabinet.
Turkey baster in reservoir
The new vs the old nasty stuff after just 1 year
Treburkulosis (05-12-2024)
LS1Tech Administrator
Received 1,592 Likes
I do the turkey baster method for this as well, but I only do that every two years. However, two years time only equals about 500-600 miles for me, so it's never had a chance to get that dark. What I take out is usually about the color of the new fluid that you've shown above (golden/light brown color). The new fluid that I put in is always clear/colorless (I use AC Delco PS fluid).
NC01TA (05-12-2024)
I have been using AW32 Hydraulic fluid, same as goes in my snow plow pumps, and tractor hydraulics.... ( Is that a bad idea ?)
Maybe the next time the T/A is in the shop for something, I'll ask what they charge for a full flush to start over again.
Save the manuals!
Are all the rubber hoses original? The times I've replaced leaking PS hoses on my trucks of similar age (late GMT 400 & early GMT 800) the instructions (I actually read them, LoL) say to replace all of them because they deteriorate on the inside and you don't know it since the outside looks good. Also the stuff that deteriorates gets passes through the pump and will eventually shorten the life of it.
I honestly admit I should be flushing the PS fluid myself on my vehicles, but I don't. I think this is going to motivate myself to do it now.
Thanks for the thread! 👍
NC01TA (05-13-2024)
Yea, Just cap the return nipple, put the return hose in a jug, fill the reservoir with clean fluid, and then turn the wheels lock-to-lock with the engine off. This will pump the fluid through the system manually at a reasonable pace. Keep the reservoir filled so no air gets in. When the return line gives clean fluid, you are perfectly flushed - much better than a "pro" would do. (They will cut corners or use a machine that doesn't get everything out.)
Save the manuals!
Yea, the first time I did this I had the engine running. It's do-able but it really does move fast and with force.
One has to turn lock-to-lock to distribute the fluid and get the air out anyway. I didn't realize that first time that doing so manually pumps the fluid. No need to run the engine!!!
i have an original power steering pump and rack but not the lines, i did stainless braided an lines and haven't changed fluid in i dont know how long . mine stays clean , i think you need to replace your lines at this point .
Second on the turkey baster method. What @sjsingle1 and @wssix99 are suggesting sounds fast and thorough. I have the handheld vacuum pump thing to draw air out as well. @NC01TA are you still on the original steering rack, and pump? Do you have the stock PS cooler also?
Replaced the stock PS lines on my 01 last winter. Had a leak and the all the hoses were pretty shot at that point, think I was around 88k miles. Think you would benefit from new lines before you start to leak like I did. I also put on a Turn One PS pump but that was overkill.
