Clutch option?
Old 07-07-2024, 09:40 PM
Jfwyatt1's Avatar
Default Clutch option?
I am in process of finishing my 70 camaro restomod and its time to pick a clutch . Car will weight around 3000-3100 lbs it has a built 6.0 ls that should be in the 500-550 hp range to the tires backed by a stage 2 built fbody t56 transmission. It will be a play car that will get driven on weekends and to shows ect. Will a luk ls7 clutch be an option or should I be looking at something more aggressive?
Old 07-07-2024, 10:42 PM
wannafbody's Avatar
That's about at the limit for a LS7 clutch. I like my Diamond Stage 2 from Texas Drivetrain Performance. It's organic on one side and ceramic on the other. It has good holding ability.
Old 07-11-2024, 05:28 AM
LS1-IROC's Avatar
I ran an LS7 clutch for years behind a 525rwhp turbo car and it never missed a beat. If you are trying to save some money, that's what I would use. I just put in a Tilton organic dual disk clutch for added capability but it doesn't drive nearly as nice as the LS7 clutch did.
Old 07-12-2024, 01:18 PM
bthomas's Avatar
I’d skip the ls7, it’s right there for capacity, but mostly because it’s a stupid heavy assy.
showdog75 (07-16-2024)
Old 07-12-2024, 07:37 PM
the_merv's Avatar
I have a healthy cammed 6.0l in my MCSS, 243 Heads LS6 Intake. I built the T56 in it, car is 3500lbs full tank of gas without me in it. QP Custom 9" with 3.89 Gears, Probably a hair over 400hp at the wheels with this build.
I had the LUK LS7 Clutch Kit in it and absolutely murdered it at the track on a 4K RPM launch, on street tires. Got one pass in at a 1.93 60ft, pass #2 the Clutch put it's notice in. I use a Monster Stage 3 now, and it's solid. That was my experience.
Old 07-13-2024, 06:37 AM
Tuskyz28's Avatar
Mcleod RXT all the way
Old 07-13-2024, 01:32 PM
SLWRDE's Avatar
LUK LS7 Clutch Kit will be totally fine for what you are doing.
I put an LUK LS7 Clutch Kit in my 1973 F100 with an LS3 and TKX.
If you were going to the drag strip then I would look into a Monster or Mcleod.
Old 07-14-2024, 02:05 PM
CattleAc's Avatar
For a play car, weekend shows the LS7 clutch will work just fine. I run one in my 72 A-body wagon with the same usage your looking at. I'm nowhere near your power estimate, but I beat on it pretty hard and it has always worked great. Lots of great advice above on other options, but for the money, for your application, LS7 is fine.
Old 07-19-2024, 04:24 PM
Jfwyatt1's Avatar
Still on the fence about the clutch. Has anyone tried the McLeod super street pro clutch? Seeing mixed reviews on other groups
Old 07-19-2024, 05:07 PM
bthomas's Avatar
I’ll let you in on an industry secret. That McLeod one above, the diamond stage 2, summits 12” clutch, ram’s 12” clutch, pretty much all 12” clutch’s on the market that have a metallic/organic disk are exactly the same. The pressure plate is a different color, but they are all the same clutch.
Old 07-19-2024, 05:26 PM
01CamaroSSTx's Avatar
Received 1,893 Likes on 1,368 Posts
Monster SC Series clutch against anything McLeod puts out.
Quick Reply: Clutch option?
