L92 Sectioned Head Pics.....Porters beware!
Here's a shot of the unfinished chambers.
Note that there are no spark plug holes.
The main purpose of this exercise is to determine how much casting thickness there is in some critical areas of an unported head.
This is a shot of the intake port cross section.
This shot shows the deck thickness.
Note that this casting was not machined to the finished deck height. It was .055" thicker than the finished heads I have. As you can see there's a bit less than 1/2" of material supporting some of the head gasket sealing surfaces.
The back wall of the the chambers seem to be thick enough as evidenced in this shot. It looks like a little over 3/8" wall thickness here.
Several thin spots surrounding the intake and exhaust ports are evident. This shot is looking at the back of the intake bowl on one side of the guide boss.
And heres a look at the as cast exhaust port section.
Note the lack of roof section thickness here:
If I come up with any more relavent pictures I'll post 'em up.
Richard
Thanks,
Bill
-Geoff
No doubt there's working room to improve airflow in these heads, but I wanted to note the ultimate short coming of these heads. That being said, they're still an impressive part from a major automaker.
Richard
-Geoff
Richard
Great info. I agree I wonder how they compare in strength i.e. thickness to Ls6, Ls2, and Ls7 heads. I'm glad there are sponsors/vendors like yourself that are willing to do the homework and share tech. knowledge with the rest of us. Many don't. Can't wait till you offer different L92/L76 packages.
do you see any issues with th head being able to handle a solid roller spring with 300+ seat pressure
Side note...How do you like that TDI Volkswagen?
That has been several months ago so maybe they've changed their plans. On the VW, it's a great car. I'll probably never own another car for a DD. It'll get 50 mpg if you'll leave your foot out of it, but believe it or not, it's got some power. The turbo really gives it some oomph. I hope to put half a million miles on it before I have to have any major overhaul on the engine.
