5.3L 01 chevy truck Fuse box pinout
Yea that will help but I am trying to figure out where I can tie in a on/off wire that will trigger the fuse box to go hot when the key is turned on. I have the box in the computer is in and the only plug I'm using is the black main plug in the fuse box but I don't have anything to trigger the box and it won't go hot unless I trigger it manually.
This is the site I use. Been helpful for me.
http://lt1swap.com/2000harness.htm
Fuse block specif.
Neat about using the underhood fuseblock, only a few outside wires needed for the engine, + we used the block to power turn sig headlights etc... on the 52 Pontiac.
http://lt1swap.com/underhoodfuseblock.htm
Fuse block specif.
