Single Digit Club Running 9s or quicker? Damn!
9’s N/A
Old May 24, 2020 | 02:27 PM
onebadbowtie86's Avatar
Default 9’s N/A
Went to a test n tune yesterday, made 6 passes and got the car working pretty good on the new n/a build. Air wasn’t great, 2800 feet d/a and I’m blowing through the yank ss4000 converter, 18% slip at 7000, crossing the stripe 7400-7500 rpm. Can’t wait to run in some better air even with the car setup the way it is right now, hopefully crack the 5’s in the 1/8.
Old May 24, 2020 | 02:33 PM
Tuskyz28's Avatar
Car looks great and hauling more than just ***.
Old May 24, 2020 | 08:33 PM
Thanks man, I'm not disappointed in how it runs.
Old May 24, 2020 | 08:53 PM
Tuskyz28's Avatar
What suspension mods you have? That 60ft is serious business.
Old May 24, 2020 | 09:10 PM
Bmr extreme short torque arm, lca relocation brackets, mwc tubular lower control arms and anti roll bar. Bilstein/stock shocks and springs. 3250 pounds race weight.
Old May 25, 2020 | 07:51 AM
sxc Z28's Avatar
Nice work! Something I’m ignorant of is how to calc converter slip. Is it something you log or just an online calculator?
Old May 25, 2020 | 12:12 PM
Old May 25, 2020 | 12:48 PM
I use my log from my run and the tci slip calculator from their web site.
Old May 25, 2020 | 12:55 PM
sxc Z28's Avatar
Thank you. I tried using the Wallace racing calc but it’s not very good. That tci one works great.
Old May 25, 2020 | 04:03 PM
Kingc8r's Avatar
Car is rolling out, I look forward to seeing what it does in better air.
Old May 26, 2020 | 05:10 PM
jhshnh's Avatar
Very nice runs. Sixty ft is awesome. Engine details? Gear?
Old May 26, 2020 | 09:06 PM
455 4.190”x4.125”. Gmpp ls3 heads, hyd. Roller. 4.10 gear.
Old May 27, 2020 | 09:09 PM
NHRAFORMULA00's Avatar
You are 3 tenths and 3 mph faster than my car with the same gearing. I ran a best of 10.04 at 134 on a 1.29 60ft at a raceweight of around 3100 lbs. I do not think you are slipping that much. Weight might have a little to do with it. Your mph and ET are right on parr. What was your shift extension on the gear change???
Old May 27, 2020 | 09:30 PM
On my log, converter flashes 5800. shift at 7100 drops to 6500. 7500 at the end of the 1/4. according to tci calculator im at 18% at 7000, around 14% at 7400, but thats pretty far past where my motor makes peak power.
Old May 29, 2020 | 02:02 PM
95sscamaro's Avatar
Car looks great, with more left in it!
Old May 30, 2020 | 12:02 AM
it should be dropping to right around 7200- 7300. Have it tightened up. Even if you do have it tightened up your E.T. is not going to change much at all. I went thru 3 converters before settling on the circle-d. One was too tight, then too loose, E.T barely changed at all.
Old May 30, 2020 | 12:22 AM
I'm going to most likely just run this converter for the summer and change things up this winter, either different converter, or a powerglide. I do have 50/50 atf and john deere hygaurd in the trans to try to tighten the converter up some. going to a local track tomorrow, not as good of prep but air should be 2000' better.
Old May 30, 2020 | 05:57 AM
Tuskyz28's Avatar
What block you running ?
Old May 30, 2020 | 10:03 PM
erl resleeved ls2
made 3 passes today, mph is up to a little over 112 in the 1/8 but car would not hook at the track I went to today. spun every pass 1.41-1.46 60'.
Old May 30, 2020 | 10:16 PM
Tuskyz28's Avatar
erl resleeved ls2
Tracks are like women lol.... they all different
