400 sb in a v6 camaro
i was wondering if anyone know what needs to be changed to put a 400 sb in a 93 - 97 v6 camaro, or would it be easier/cost less to put it in a z28. im trying to get ideas for a project. im going to get the motor soon and have it built before i start on a car. let me know what you think.
thanks,
matt
thanks,
matt
I don't see how it would make a difference.. How are you gonna bolt the motor up? Aftermarket k-member, motor plate, or what? And I'm guessing you will be using a T-350 or 400 or a Glide right? There should not be a difference in a v6 or a v8 car since you will be doing away with all of the computer & wiring stuff. Just bolt it up and go man!
All you need are mounts for a V8 to bolt up to the crossmember. It's really nothing special that hasn't been done thousands of times. Hell, you can even go with a 632 big block and just use V8 mounts. Hooker and other companies make headers for these swaps. For a tranny, you can go with just about anything under the clear blue sky. I would worry more about what is going to happen to your differential when you juice that torque monster....
