Minimum CFM for 385 hp?
What is the minimum required cfm rating to produce full power in the above motor? Will the above carb limit power in the above motor?
There are conflicting answers to the above questions. An equation at Holley's website indicates my motor requires less than 550 cfm. Conversely, Holley phone tech implied 600 cfm will limit power. In a Summit catalog, the text in a Holley Street Avenger ad states "670 cfm, 300-400 hp", implying my 385 hp motor requires about 650 cfm. Is the minimum cfm 550 or 650? I'm lost. Please share the basis for your answers.
Thanks a ton.
is like the square root of pressure. 4BBL Carbs are
rated at a low pressure drop of 1.5 inches of mercury.
-Every- carb "limits" power. Not as in a hard limiter,
it's just a "tax" on manifold pressure.
The (ambient air - pressure drop) is your manifold air
pressure, your density and your mass air flow. A
750CFM carb will produce a lower drop than a 600
(duh) but presuming there's nothing nonlinear going
on, the difference at, say, 700CFM is going to be
something like:
drop750=(700/750)^2*1.5inHg=1.31inHg
drop600=(700/600)^2*1.5inHg=2.04inHg
Ooohhhh, big difference, right? Not really, because
atmospheric is 29.9inHg and the manifold pressure is
(atmospheric-drop):
MAP(ideal)=29.9
MAP(750)=29.9-1.31=28.6
MAP(600)=29.9-2.04=27.9
Now if you look at those pressure drops as percent of
ideal, you have a rough idea of how much HP is left
on the table. Say you'd have a 400HP motor if only you
could get a CARB-approved 20,000CFM UberDominator
9BBL carb in pink anodized finish...
1.31/29.9*400HP=17.5HP lost to 750CFM carb
2.04/29.9*400HP=27.3HP lost to 600CFM carb
The difference in loss is 9.8HP on a motor drawing
700CFM.
At 500CFM you would be at about 5HP less, running a
600CFM carb, than a 750. Presuming they were equally
well tuned and stuff like that.
Which is not to be ignored, because where you live
on the street is midband torque and transitional
metering, a smaller carb running at more of its
max vacuum signal will have better mixture fidelity
at the lower airflows.
Here are my questions, better distilled:
1. On this particular 385 hp motor, what happens to the 5 hp bump between 5500-5800 rpm when the OEM 750 cfm Holley 4160 is replaced with a 600 cfm Edelbrock 1400?
2. Does the bump become a plateau or a downward cliff?
The plateau is tolerable, especially if performance improves below 5500 rpm.
Yes, jim #3 you are very astute! The source of the consternation is that my builder & a couple other apparently reliable sources prefer the Edelbrock for long term reliability, a big priority for me.
Also, Edelbrock was convincing that the 600 would work significantly better below 5500 rpm.
Your opinion comparing the two carbs?
Thanks a ton.
( Engine Size (CID) x Maximum RPM ) /3456 = CFM
For example, I had a 396 ci. Big Block, and my max RPM was 6500, so
(396 x 6500) / 3456 = 744.79
The motor made 720 hp on the dyno, and I ran a Holley 750 double pumper. I had numerous people tell me I needed more carb, but the 750 was plenty after it was tweaked.
By the way, Jared, nice Camaro. Doug Herbert racing sells the best and the cheapest cams there are. You can get any size hydraulic non-roller cam you want, with springs and lifters for under $300.00. Just thought I would let you know.
Thanks alot white ta. That's the most help I've recieved on this forum yet and I didn't even have to ask a question. Good thing I made that stupid comment.
By the way, I better make sure my dad doesn't see you making 720 HP with a 750. I am stealing his 750 as soon as he puts an 850 on his 396. I dont have money for a carbright now! I am running a 600 cfm edelbrock. He's making a little less than you, he suppose to be about 550 rwhp in a 396.
Take care.
