which rotating assembly should I choose?
I would aim for between 9:1 and 9.5:1 for a centrifugal blower - that way you'll have good off-boost performance and still be able to run decent boost with a good intercooler.
Are you going to run EFI?
Jim
Derek
)there is the patriot performance genI sbc 100% CNC Ported heads .... just check if your intake and heads are vortec then a diff intake will be needed ....
my point is heads in general (not disgarding the cam and intake)
are the power makers LS1 is 5.7 L and LT1 is the same and somebodys grandpa`s 1984 suburban sbc 350 is the same ...
put the same cam (cam spec) on them all and see the flywheel HP
now put the same supercharger on them all same boost of course and see how much they make .... LS1 isn`t better because it`s an aluminum block!
sometimes I keep writing as if I`m talking to people that doesn`t know what I`m saying and explaining manythings and sometime repeating .... I don`t mean to I`m just that type of explain and talk talk talk ....sorry if this is out of the subject and if it`s something you already know and wasn`t looking at and I wasted your time
just a thought
I vote just choose the cheapest balanced 4340 forged assembly and since you`re paying anyway make it a 383 or even a 391 with the same 30 overbore if I`m not wrong. Last edited by YenkoST; May 2, 2006 at 02:38 PM.
