High RPM small blocks?
Just remember that rpm is WAY tougher on a motor than nitrous or a supercharger. The loads quadruple as the rpm doubles, which means the loads at 7200rpm compared to those at 6000rpm are 144% higher.
Jim
"010" 4 bolt main block
Forged SRP 16cc Dished pistons
Crower 4340 I Beam rods
Eagle 3.75" cast crank
Clevite H series bearings
Iron Eagle Platinum Heads
CNC'd by M2 Racing
242cc intake runner
321 CFM @ .700
66cc chamber
PSI Springs 235 lbs closed, 620 lbs open
Jesel comp series shaft rockers 1.6:1
Crower Custom Billet Steel Cam 254/257 @ .050 .712/.712 lift
Edelbrock Super Victor intake
Port matched to the heads
Fel-Pro 1209 gasket (2.38" x 1.38")
Holley 950 HP Carb
Wilson Manifolds 1.5" Carb spacer
Custom stepped headers 1 7/8" to 2"
This dyno sheet was before the intake was port matched and with 1 5/8" headers. 9.5:1 Compression. 43* total timing.
http://s5.photobucket.com/albums/y19...=DynoGraph.jpg
Also if you are wanting that screaming sound I guess you may be referring to the noise a Ferrari makes. Sadly it is impossible to replicate with a SBC.
Generally to spin a motor (any motor) at high rpms you need several things.
One a built and very well balanced bottom end. Evidenty at such high speeds it needs to be in tip top order. Also you'll find very few long stroke motors that like revs. Most use a large bore combined with a short stroke as this means each piston only has to travel a shorter distance and far less inertia is involved.
Moving on to the valve train, OHV and push rods are not ideal for high rpm use. This is due to the rotational mass and indirect operation of the valves. You will need a heavy duty valve train setup to reliably handle high rpms but this will result in other down falls.
Following on from that if you plan to spin the motor that high you will evidently want to make use of the rpms so you will need some extra good heads and an appropriate cam selection to make power in higher rpms. But this is where you face another issue. Due to lack of curtain area 2v engines (OHV or OHC) have a limited rpm range in where they will make power, e.g.
x = operational range
1000-1500-2000-2500-3000-3500-4000-4500-5000-5500-6000-6500-7000-7500
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX - stock(ish) setup
------------------------------XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX - cammed and setup for high rpm use.
You will only ever have the same range of rpm to use but due to setup you can select what that range is but not increase it.
To provide enough breathing capability at high rpms you will need much larger valves than stock, but this means heavier spings and increased wear/friction on the the valve train. Also low rpm driveability will suffer greatly.
Increased curtain area allows better control at lower rpms and better breathing at high rpms, this is acheived by running multivalves such as a 4 valve setup. There is a company that makes some rather clever 4 valve heads for Chevy SBC's, check out there Advanced Tech forum there was a whole debate on it and multivalves (I can't remeber the name of the company right know). So this would sort out the breathing abilty although running 4 valves per cylinder on a push rod engine will certainly add more stress to the valve train but I beleive this system is fairly well proven.
Also if you plan on a turbo you don't particulary need high revs. As this would require a turbo with sufficent abilty to provide boost at such rpms which means it is likely to be more laggy in the lower rpms.
Lastly if it is the Ferrari screaming V8 sound your after, the reason you won't get it is because a Ferrari V8 is a DOHC short stroke motor. But the most significant factor is it uses a single plain crank. This means it has an even firing order, one bank then the next and so on. A traditional V8 has an uneven firing order where you will end up with two cylinders from the same bank firing one after the other. This is what gives the well known V8 rumble we are all used too and it is precisley why a Ferrari V8 doesn't make the same sound. Very few V8's are like this, Ferrari, TVR and Lotus are the only production ones I know of.
The Ferrari V8 is essentially two Striaght 4 engines with a common crank shaft, where as a SBC is essentailly two V4 engines.
Good luck with your project and I hope you get it sorted
https://ls1tech.com/forums/lt1-lt4-modifications/423546-32valve-lt1-progress.html
