383 Build HP Estimates?
Bore = 4.030
Stroke = 3.75
rod= 5.700
Eagle Competiton Rotating Assembly
Flat tops with 11.1 compression
AFR 195cc Street Eliminators 64cc Chambers
Comp Cams Xtreme Energy XR270HR-10 Hydraulic Roller Cam
Lift: .495''/.502''
Duration: 270°/276°
Comp Cams Pro Magnum 1.6ratio rockers
Edelbrock RPM Air Gap Intake
Speed Demon Carb 750cfm
Derek
Here is the link
http://www.chevelles.com/forums/show...highlight=DYNO
Thats the next size cam
Xtreme Energy XR676HR Hydraulic Roller Camshaft Only
Lift: .502''/.510''
Duration: 276°/282°
RPM Range: 1900-5600
