SBCvsLS1??
BTW: Even carb'd the LSX costs more. Warhawk block and custom intakes and belt drive distributor. SBC is much easier and cheaper.
For example on one system my car at 3200lbs makes 855rwhp and goes well over 165mph with a glide on a 28 tire. Now I bet you LSX makes more power then that...but there will be no 165 mph from you! Thats my point. mph is hp! What is yours? At least compare apples to apples!
i still can not find any info about the 1000hp n/a sbc, but again i am only performing a google search.
So i'd consider that ball one.
your second strike i need to research. so until i can its still a strike
The parts price difference,stock for stock we know the ls1 stuff is better, thats not in question, correct? Depending on which vendor you go to there can be a 200-400 dollar difference most cranks untill you reach the top where they equal out. Rod, bout the same price , bearings same price, heads we can look at afr (or any other if you want) from JEGS:
SB-Chevy Competition Cylinder Heads - 210cc Intake Ports
033-1103 SB-Chevy Competition Cylinder Head
210cc Intake Ports
Standard Exhaust Port
Angled Plug Type
66cc Combustion Chambers
80cc Exhaust Ports
1.550'' Roller Valve Spring,
220 lbs. Seat Pressure
.670'' Max Lift
Sold As Pair
More Details
$1,999.99
LS1
033-1510 SB-Chevy LS1 Mongoose Cylinder Head
205cc Intake Ports
CNC Ported w/Parts
85cc Exhaust Ports
1.290'' Dual Hydraulic Valve Spring
135 lbs. Seat Pressure
.600'' Max Lift
Sold in Pairs
More Details
$2,249.99
now this is just a small sample we can go as high as we want for both style engine and we could both go to our respectible vendors and find great deals on all of the items needed, pricing can go either way . Honestly we could both post up pricing all day long to counter the other but The blanket statement that ls series is much more to build (engine wise, not considering EFI) is untrue.
infield homerun for ls1's?
, if by crack you mean large amounts of coffee then yes sir!
Spray, not to sound like an ******* because i am not and i know how somethings can be read wrong when it is in text and not a spoken word, but come post up some legit hard facts like Marc 85Z28 to get your veiw across, just because i dont agree wont mean you are wrong , it just means i dont agree. Again i do like where this is going and Marc 85Z28has posted some interesting things that i did not know about and need to research, but again i and other dont happen to agree, just like you,Marc 85Z28 and other dont agree with what i type. What this can do is expose some truths and facts to counter false statements that may have been floating around. I for one am going to research what Marc 85Z28 has posted because i have nothing better to do in my poor crack induced coma
I have a link here... where a stock "rebuild" that has a 150k miles on it, was pulled from the junk yard and powerwashed, sprayed with WD40, then put back together with some shitty *** 1970s smog TRUCK heads (1.72 intake valves... unported). TPI on the top with two old *** GN turbos (plus some nitrous) and it makes 660 some horsepower through a Automatic tranny, unlocked converter, and a 9 inch. MOTOR IS A STOCK 350 WITH GOOD HARDWARE. ANd has held for numerous dyno runs and passes down the 1320 (and running a high 9).
The fact is any platform is worth building. The LT1 is a waste of time if you have the funds to go to a SBC or a LS1.... but you can't forget that cam/heads and some nitrous will get you 10's in a "slow" lt1. No one can say that a certain "platform" is better than the next. They both have their ups and then their downs. Dont make me point them out, you know they both do.
Why dont you all quit arguing and think for a minute... JESUS
BTW... here is the link to the 9 second junkyard motor
http://www.turbomustangs.com/smf/ind...?topic=61219.0
How about www.shafiroff.com
Keep in mind these engines include ALL NEW parts, nothing reman or refurbished. Those power and reliability levels can easily be achieved cheaper, as long as the engine is used in an environment where it doesn't see continuous full load high RPM operation.Since when did the AFR head prices go up for the SBC and down for the LS1? In 2004 I bought some 195s direct from AFR for $1250. The 210s were the same price... Essentially I bought a set of aftermarket "top of the line" aluminum heads for less than a set of ported stock LS1 castings. Then compare cam prices, and intake prices...
And to the comments about the "used" SBC stuff. Thanks for kicking yourself in the nuts, as that's another SBC merit - they're EVERYWHERE! I can build a SBC from WalMart, 7-11, or McDonalds even
Remember, the LS1 was a "clean sheet" design. GM wanted to address all the shortcomings of the old SBC. They copied their designs directly from the SBC aftermarket. So basically anything GM put into the LS1 someone put on an SBC decades ago, and proved it to the point that GM copied it.
Want to know about fast LS1s, Terminators, Supras, and turbo imports? You'll find them on the internet. Want to know about the REAL high performance vehicles? Get off the computer and go to a track.
hmm who could that be? me
hmmmmmmmmm didnt i already cover that?... what do you mean on one system? are you talking about a computer model mock up race?
i am ditching he sbc out of my car for a few reasons....i am not going to get a decent fuel injection system for under 2k for a built sbc unlike the one that comes stock on a ls1 car...aluminum block....what is the cheapest one...like 4k?????.....the heads alone on the ls1 are FAR superior to any stock chevy head out there...what stock chevy head offers 330cfm out of the box untouched?....these motors are reliable as **** and some guy on camaraoz28.com a few years back had a 98 with 320k on the clock...no small block has one coil per plug granted ou can add that yourself...this comes stock....to me its a way better designed motor unless i wanna spend a shitload of cash on a 434 like someone i know to run low 9s and then have a nitrous burp and blow a ring out and pay a 9k for a refresh on the motor...i am building a road race set up car and what i am doing is the way to go...!!
Marc 85Z28, nice post with real information, but again are we talking about cars and ets or engines? If the car is light and has a decent supension its gonna fly no matter what.
And i am merely speculating on what i have read in this thread. You clearly dont have the experience of either engine designs. And the people in this section which are trying to help people with sbc should not be wasting their time with you is all.
if your starting from scratch and using used/new stuff ,thats gunna boil down what "Deals" u come by first.. but if ur buying everything new.. the sbc is going to be cheaper to build. thats my view.
or do us a favor and go away.
