Southern Members A regional forum for all our down South members.
Columbus, GA
Old Sep 2, 2010 | 07:18 PM
  #2641
Ga_Knightmare's Avatar
Originally Posted by zz17iroc
When you guys were running it looked like you where trying to manually shift the car. Next time let the tranny do it's job. The first time I've ever manually shifted my car is when I got my shift kit because of the 2-3 shift lag. But if your tranny is stock with no mods then put it in D and mash the gas. I should have my ALDL cable from Moates by the end of next month to help with your tune later on down the road. Start with a basic tune up and start saving for a new GM opti-spark. Because it will go out on you sooner or later. So when it does you'll have your replacement on the shelf.
This is so true as Craig knows since he helped push mine off the road recently because of the Opti failure
Old Sep 2, 2010 | 08:52 PM
  #2642
Mightymike2000ss's Avatar
From: Home town Clive,IA current town FORT BENNING GEORGIA
Originally Posted by 2slow2flurry-ous
I gotta work friday night, unfortunatly. Anybody going to sonic saturday night? I'm actually off for once, wow. I'll have to whip the s-10, but figured we could go get a bite to eat or just chill up at sonic and laugh at ricers.
ill be down for that as long as we can pull craig, and ron along. i would say Tim but hes got plans already
Old Sep 2, 2010 | 09:12 PM
  #2643
greasemonkeysoldier's Avatar
nah i can't on Sat. i gotta cram hardcore for this E-6 board....i really shouldn't be going out friday night either, but oh well...lol
Old Sep 3, 2010 | 03:35 PM
  #2644
sheikss's Avatar
Ended up being a bad plug wire. Might install the tick tomorrow while the old lady packs up. Heck, I might even finish up the linelock and the nitrous.
Old Sep 3, 2010 | 06:31 PM
  #2645
VindicatedLS2gto's Avatar
put my new tsat in, car seems to run a lot cooler. HOWEVER the gauges pissed me off to no end so theyre just chilling in the pod.
Old Sep 3, 2010 | 11:12 PM
  #2646
Damian's Avatar
LSX Mechanic
A t-stat does you virtually no good without the fans being dropped down via a tune. A car with a 160 stat will still run @ 210 if the fans aren't programmed to kick on early. Only during HWY driving will you see any kind of cooler temps.
Old Sep 4, 2010 | 12:10 PM
  #2647
12.4 @ 110! with 2300 DA....I'm still excited as hell about it...about to scan my timeslip so i can post it and finally get into the 12 sec. club.....11 secs. is right around the corner guys...i can feel it....just gotta work out my launch and figure out the whole "burnout" thing...lol
Reverse burnout FTW! lmao
Old Sep 4, 2010 | 12:27 PM
  #2648
congrats man thats some good ****, plus its nuts to see your car is pretty much stock. it';; run really strong with a cam man. and for what its worth im pretty sure you blew everyones mind with that reverse burnout.
Old Sep 4, 2010 | 02:28 PM
  #2649
zz17iroc's Avatar
Ron I take some blame for your last past. I forgot how it feels when you see all your hard work pay off and your car performs better than what you expect it to.
Just need more seat time at the track.
Old Sep 4, 2010 | 03:06 PM
  #2650
i was pretty impressed last night craig, at how smooth your car was at cruising at those speeds lol i felt every single bump we took FML!!!
Old Sep 4, 2010 | 03:36 PM
  #2651
OUTLAWZ RACING's Avatar
Reverse burnouts work, It allows u to heat the tires up both ways LOL!!!!!!
Old Sep 4, 2010 | 03:38 PM
  #2652
Just need more set time at the track.
nah man, it's not your fault. you're were just trying to help me out. I'm the one who didn't just take my time and stay focused. But yeah, definately need a lot of practice. Honestly I think a line lock will help me out a lot. i will have less to worry about when doing a burnout then...i will be able to focus on the throttle more then as well as being in the right gear...lol
Old Sep 4, 2010 | 03:41 PM
  #2653
i'm pretty sure i messed something up on that last pass though....i think my torque arm might have bent or something....there was a new/strange vibration when i was drving back from the track last night and i could here some new metallic rattle sound...i'm going to go check it out in a little bit.
Old Sep 4, 2010 | 03:59 PM
  #2654
sheikss's Avatar
Need to bleed brakes, plug master cylinder line in, bleed clutch, and then finish the nitrous and I will be done with installing parts. Just need to adjust pinion angle, fix rattling exhaust, and put the relocation brackets on. Tried calling you today Craig so I could get these brakes and master done. I can't get the stock line to release from the slave. I cut the old line to get the old one out and new one in.
Old Sep 4, 2010 | 04:01 PM
  #2655
sheikss's Avatar
I can square him away on the fans if he gets credits.
Old Sep 4, 2010 | 04:33 PM
  #2656
Mongoose_TA's Avatar
Congrats on the run Ron. Hopefully next time ill be out.
Old Sep 4, 2010 | 05:13 PM
  #2657
sheikss's Avatar
It's off
Old Sep 4, 2010 | 05:25 PM
  #2658
My cars fans come on pretty early, Im pretty sure they squared me away when they did the dyno tune.
Old Sep 4, 2010 | 09:33 PM
  #2659
for those of you who care, i was up at walmart today. just got back and noticed a car i havent seen in a while from far away i thought i saw a 240 but one i got close noticed it looked my like an R32 got close and saw that it actually was i was kinda shocked. it was only a GT-S tho
Old Sep 4, 2010 | 11:26 PM
  #2660
firehawk238's Avatar
