99 Built turbo Ls1 Camaro $14,000
sold sold sold
![](http://i103.photobucket.com/albums/m145/rideonefast/1.jpg)
![](http://i103.photobucket.com/albums/m145/rideonefast/3.jpg)
![](http://i103.photobucket.com/albums/m145/rideonefast/5.jpg)
![](http://i103.photobucket.com/albums/m145/rideonefast/7.jpg)
![](http://i103.photobucket.com/albums/m145/rideonefast/9.jpg)
![](http://i103.photobucket.com/albums/m145/rideonefast/09-06-07_1513.jpg)
![](http://i103.photobucket.com/albums/m145/rideonefast/09-06-07_1512.jpg)
![](http://i103.photobucket.com/albums/m145/rideonefast/09-06-07_1511.jpg)
![](http://i103.photobucket.com/albums/m145/rideonefast/th_06-06-07_1659.jpg)
![](http://i103.photobucket.com/albums/m145/rideonefast/th_04-20-07_2339.jpg)
![](http://i103.photobucket.com/albums/m145/rideonefast/th_05-29-07_2202.jpg)
1999 Chevrolet Camaro Z28 Ls-1 Blue in color with blue ghost flames. manual 6 speed (m6). This car is incredibly fast with traction you would not believe. Don't ask for track times because it hasn't been to one. To many people tear up there cars at the track trying to exceed the cars potentional. This car started off with a stock engine, tune, and STS turbo kit and dynoed 487.26 rwhp and 541.41 rwtq at only 7psi of boost.(Pictured) Listed below is unless i forget something all of the modifications done. It has leather seat and t tops also. The smog and the cats were removed so this is consider an off road only vehicle.
Squires Turbo Systems turbo kit with upgraded T-67mm turbo and intercooler
Rear lower controll arm relocation brackets
Adjustable lower controll arms
Panhard bar
Shocktower brace
Lowering springs
Subframe connector
Slotted front brake rotors and pads all the way around
Boost gauge and Innovate motorsports wideband O2 Digital Air/ fuel ratio meter
3 Inch smooth cowl hood
Ghost flames
Engine Build which included - Vat block, Race bore & hone with torque plates & plateau hone, file fit rings, check line bore, balance race engine, balance springs, mill heads, Port and Polish heads, racing valve job
List of internals
Diamond 9.3:1 Forged pistons, Moly piston rings, Eagle 4340 forged crankshaft and connecting rods, Race main, rod, and cam bearings, ARP Main studs, ARP head bolts, Cometic mls head gaskets, timing chain, high volume oil pump, Ferrera Turbo race valves, thunder racing push rods, msd 8.5 plug wires, pacesetter longtube headers, ngk tr6 plugs, 60lbs injectors
Spec super twin clutch kit- Organic disk 900 tq rating --- yes it does have 2 clutch disk
new flywheel and pressure plate balanced with the engine also slave cylinder new
Sts Boost controller controll form 7psi to 15 psi in boost
Sts methanol injection kit
aluminum driveshaft
optima battery
billit grille
The cam that is installed is a turbo custom camshaft that sounds amazing. the Duration @.050 intake 230.7 exhaust 224.0 valve lift w/ 1.7 rockers intake .576 exhaust .561 with a lobe seperation angle of 111.4 degrees the wheels are boyd coddington 17x10 with nitto drag on rear and nitto up front with about 90% tread wear left on front could use some new rear tires though. I am a non smoker and do not allow people to smoke in it.
Asking $14,000 Car is Located in Baldwin Co AL.
Panhard bar
Shocktower brace
Lowering springs
Subframe connector
Ghost flames
List of internals
aluminum driveshaft
optima battery
billit grille
well if your looking for a car that attracts less police intrest. i have a ss convertible with 113k white on white with white leater interior. i can give you some boot also if your intrested ?
Location: sneaking in your back door as you leave!/cartersville ga
come buy it. everything i have is for sale!!!
sorry for the hijack, but you are in the southern section.....so i aint that sorry![Hijacked!](https://ls1tech.com/forums/images/smilies/myhijacked2.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
ttt for ya
ttt for ya
what comp. ratio does it have ? what was done to the heads exactly . are they just stock ported with valves and springs. how far are you away from six flags in ga. i am very intrested in the car ! where was all the work done by who ? does she have any problems , dependable , reliable ? stock gear ratio , can you post some interior pics please ?
9.3 to 1 diamond pistons. port and polish with thunder racing springs and push rods and ferrera turbo valves which are better than titatium. Professional Engine in Mobile AL. Dependabable could use rear tires. stock gear ratio and im 7 hours from six flags
