did every SS have the Bilstein Ultra Performance Suspension?
I know that every SS comes with a different suspension.... But Does every SS comes with the Bilstien Ultra Performance Suspension???? Or is this extra?? And if it is extra is it a good thing to Have??? Thanks
((((((Administrator))))))
It was an option like felton316 said. There was also a 1LE suspension option.
Here is my SLP option window sticker:
>>>>SLP Window Sticker<<<<
Peace,
Craig.
Peace,
Craig.
Forbidden
You don't have permission to access /s/image5/9/74/64/64997464uFLXsK_ph.jpg on this server.
Apache/1.3.27 Server at community.webshots.com Port 80
Webshots doesn't like links.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Originally Posted by camarols1
Forbidden
Webshots doesn't like links.![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Maybe this one will work:
>>>SLP Sticker<<<
Yeah...it was an SLP installed option. Here is the description from SLP's sales literature:
Hollow 35mm front swaybar significantly reduces body roll. Includes revised endlinks, reinforced body mount brackets and firmer bushings. Progressive rate springs (Eibach), front and back, have been designed to provide a comfortable ride and superior handling. Re-calibrated Bilstein shock absorbers provide improved handling and maintain ride quality. Rear lower control arms with firmer bushings (1LE) reduce wheel hop under heavy acceleration. Larger 21mm rear swaybar and bushings decrease body roll.
This package lowers the car about an inch or so.
You can see some pics of my car's stance here.
Originally Posted by EvilSVT
Mine is identical to yours except i have the 10 spoke slp's and no key fobs...
Craig
Craig
i think slp has a handling package that has either most of this stuff if not all of it. go to their website www.slponline.com
My Firehawk has the Bilstein, says it right on the door jamb sticker just like davered00ss said. Pretty much has everything lawman said in his post, very similair to the way it's worded in my '01 hawk literature. If I remember correctly it was about an $1800 option in '01.
2001, 2002, billstein, bilstein, bilsten, cam, camaro, canaro, option, performance, perfrmance, ss, suspension, ultra, ultraperformance, z28
