Hot -new Product- Plx Obdii! Dm200!
Hey guys, some of you asked for it so here it is!!
we have the NEW OBD2 gauge from PLX. This thing is wild!
http://www.plxdevices.com/products/dm200obd/
![](http://www.plxdevices.com/NewsLetters/OCT2007/OCTOBE4.jpg)
Intelligent Multi-Functional Display (iMFD)
Universal 2 3/8" (60mm) OLED Color Display for all Sensor Modules
* Winner of 20 SEMA Awards for Best New Product
* Displays up to 50+ sensors
* Plug and play to 1996+ vehicles and up
* Compatible with all obd2 protocols
* Installs in seconds
* iMFD sensor modules compatible
* Fully customizable
* Interfaces with your PC
This one gauge does it ALL!!!
View all your parameters from your PCM on this one gauge. Customize the gauge face/colors on your PC!
The DM-200 OBDII installs in seconds. It's capable of displaying standard obd2 sensors such as RPM, Vehicle Speed, Engine Load, knock,Timing, Throttle position, MAP, MAF and numerous other PCM parameters. Simply plug the OBD connector into your vehicle's OBD2 port located on all passenger side 1996+ vehicles and up. The DM-200 OBDII is also compatible with all PLX iMFD sensor modules for expanded functionality. Read and reset error codes.
WE are offering a ONE TIME discount on these. strictly to LS1tech members.
You can add the option for Wideband Air/Fuel to the above gauge for an additional 185.00
YOU MUST PM me to get on the list, No payments will be taken until all 15 units have been accounted for VIA PM. If you are on the list and change your mind please let me know ASAP where i can give this deal to another member!
PM Me for Pricing INFO!
Thanks again guys,
Derek
Thanks again guys,
Derek
Take a look at the vid to see just how wicked this thing is!
http://youtube.com/watch?v=957TTByL0Ls
The Air fuel will only work if your purchase the sm afr module.
you simply hook it up to the gauge and you can read all your OBD2 parameters and your Air/ Fuel.
If you just want to read Air/Fuel click the ad in my sig.
Thanks,
Derek
Thanks,
Derek
Yep, we reached the min. amount of orders so we are able to offer these at the best price possible. Please just shoot me a PM if your interested.
Thanks alot,
Derek
Thanks alot,
Derek
Update:
We are completely out of stock on these units. We will have more around the end of May..
(slight back order through PLX)
I will update this thread when we have more in stock.
Thanks a bunch for all you guys that purchased these!
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
