Feeling the need to stroke it? Lunati discounts inside!
![](https://www.holley.com/HiOctn/ProdLine/Products/IEC/IEC_pics/fLS1_LS6Rotat.jpg)
Lunati currently has 14 different LS1 and LS6 rotating assemblies available and they will have two new kits coming soon. The Lunati engine assemblies are made with the finest Lunati engine components, including a Lunati Pro-Series crankshaft, Lunati Pro-Billet connecting rods, Lunati forged pistons, rings, bearings, and piston pins.
If a turbo or blower is to be used, they recommend 8.5 CR with pump gas. For racing and race fuel you can move to 12.5 CR for maximum performance. The pistons and rings come in 0.005" oversize to accommodate honing to clean up the cylinders. The top ring is a 1.5 mm moly plasma pre gapped ring, second ring is 1.5 mm cast-iron reverse-twist, and the oil ring is 3 mm three-piece. The assembly is internally balanced and the reluctor ring is installed. All this, and with your choice of up to 408 cubic inches!
We are offering discounts on all of the Lunati stroker kits and cams that they produce. Pistons, rods, ect... can also be purchased seperate. Pricing is available by e-mailing tbyrne@tbyrne.com or give Julie a call at 1-508-678-2071 Monday - Friday.
Have a good day!
Tom
The new LS1 kits are -
EA035-427 LS1 Engine Assembly 427CID 10.6:1
EA035-434 LS1 Engine Assembly 434CID 10.6:1
EA035-447 LS1 Engine Assembly 447CID 10.6:1
EA135-427 LS6 Engine Assembly 427CID 10.6:1
What do you have to offer in the way of 4.030" forged boost pistons in the area of 10.5:1 for 6.100" or 6.125" rods? Any help would be greatly appreciated.
-Mike Chapman (mikec@gotmoorespeed.com)
Gotmoorespeed.com
Gotmoorespeed.com
Most e-mail is answered within 24 hours (usually less) so you should have seen a reply. Please resent your request when you get a chance.
Thanks,
Tom
![](http://www.tbyrnemotorsports.com/Banners/camarobanner.jpg)
Order line - 1-877-4-TBYRNE
E-mail - tbyrne@tbyrne.com
SUPERCHARGER DISCOUNTS AVAILABLE!
Thanks,
Tom
